Re: Wheel contest
Re: Wheel contest
Here's my old school wooden wheel.
Maybe not the most practical... |
Re: Wheel contest
Random design for fun. 3 inches; the iProperties box says it's .189 lbs...
![]() ![]() The tread should have more raised lines on it between the FIRST logo imitations, but the emboss was taking forever to calculate the way it is now, so I left that out for now. |
Re: Wheel contest
Wow, that's hot. You've got to tell me how you did the FIRST logo on the curved surface like that.
Re: Wheel contest
After revolving the inside part of the tire, I created a sketch normal to the tire's surface. Then I drew up the FIRST logo. (It's just an imitation of the logo; I guess you could trace a sketch on top of the real logo image to make it exact. All those dimensions are there just because I wanted it to be fully constrained.)
![]() Then I made a rectangular pattern of the logo, inside the same sketch, making sure that the width of the pattern did not extend past pi * diameter of tire surface. Then I embossed the sketch, choosing a raised emboss and "Wrap to Face" with the tire surface. You could also emboss one instance of the logo and circular pattern the Emboss as a feature. Last edited by Dan Zollman : 18-11-2006 at 19:24. Reason: wrong img urls |
Re: Wheel contest
I needed something stronger than our typical omniwheels because they'll be cantilevered and exposed in the design I'm working with now.
There's no reason wheels can't show a bit of team spirit ![]() |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| 3 wheel vs 4 wheel vs 6 wheel | locohammerhead | Technical Discussion | 18 | 20-01-2005 00:56 |
| 2-wheel versus 4-wheel drive | Ben Mitchell | Technical Discussion | 23 | 07-11-2003 00:50 |
| Wheel Modifications? | archiver | 2000 | 1 | 24-06-2002 00:13 |
| Wheel | geo | Technical Discussion | 3 | 25-01-2002 20:03 |
