Go to Post There is no exit strategy in FIRST - RoboMom [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 20-10-2006, 19:24
Frenchie's Avatar
Frenchie Frenchie is offline
AKA: François Baldassari
FRC #0469 (Las Guerrillas)
Frenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to behold
Question [OCCRA]: Fuse Block
Is it possible to use a 12 slots fuse block instead of the provided 10 slot one? Using all the motors/pneumatics available to us would require more than 10 fuses.
Thank you.
Francois
Fuse Block and Panel Dwgs indieFan General Forum 4 14-03-2006 01:39
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Warning! Check the screws on your Maxi fuse block! Roland Electrical 1 16-03-2004 21:59
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
pic: 40-Amp Fuse Block CD47-Bot Robot Showcase 7 20-02-2004 00:23
