Go to Post ...if you don't ask, you won't get. - Billfred [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Old 10-23-2006, 01:19 AM
Onward through the fog.
Re: How Loud is Too Loud? (Cal Games)
What did you say?
(j/k)
EDIT: Our ball lift made a significant amount of noise this past year and I was impressed. And, my fingers were comfortable in my ears at times.
~ Helen Keller
(1880-1968)
  #17   Spotlight this post!
Old 10-23-2006, 09:34 AM
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
WHAT?
If you are really concerned about the noise level itself borrow a dB meter from someone and measure the levels.
There are safety standards for noise levels and hearing damage. If your robot is loud enough to cause hearing damage then people standing nearby would need earplugs, and you should not run the shooter in the pit area.
  #18   Spotlight this post!
Old 10-23-2006, 10:15 AM
Billfred's Avatar
Billfred Billfred is offline
See, this is why I bring earplugs to FIRST events. (And you thought it was because I usually wind up near SPAM.)
I might suggest a rule that MIT's 2.007 course uses in their competition, known as the Naked Phone Booth Rule. Basically, if you wouldn't want to be in a phone booth with your device while naked (for two minutes, for our purposes), it's probably not a good idea to use it.
  #19   Spotlight this post!
Old 10-23-2006, 10:40 AM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I have always been of the opinion that if the mechanicals are making noise they are trying to talk to you. I would listen and try to determine the problem. It might just be that at speed a part of the mechanism is hitting another part as in something is just slightly out of alignment. Look for wear spots on your rotating parts. Could be that the sprockets are not parallel and in the same plane. The chain would make a distinctive knock each time a sprocket tooth attempts to engage a chain link. The faster the speed the more (and louder) the knocks.
Al
WB9UVJ
www.wildstang.org
________________________
  #20   Spotlight this post!
Old 10-23-2006, 11:38 PM
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
On a serious note, refer to the table linked to below.
http://www.occupationalhearingloss.c...aring_loss.htm
Under OSHA rules, no exposure above 115 dBA is allowed, however short.
So, this answers the question: How Loud is Too Loud?
If you have concerns, borrow or buy a sound level meter.
Yes, there will be a sound meter available at the Cal Games...
Eugene
(President of the WRRF)
  #21   Spotlight this post!
Old 10-24-2006, 12:32 AM
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Eugene
Thanks that's really helpful. I would say our robot measures somewhere around the 90 level
Although we haven't found a solution to the problem (a five day solution that is ) we have managed to adjust our shooter so that we only have to reach "jackhammer speed" for a very short time.
As for metal fatigue it has surprisingly held together quite nicely and there are no visible signs of damage.
"Cooperation; because life is a team sport"
-Philip J. Fry
  #22   Spotlight this post!
Old 10-24-2006, 12:38 AM
AKA: Dr. Brooks
no team (WRRF)
Only 90 dbA?, you can run that all day and we will call it entertainment!
Eugene
  #23   Spotlight this post!
Old 10-24-2006, 09:00 AM
...Although we haven't found a solution to the problem (a five day solution that is ) we have managed to adjust our shooter so that we only have to reach "jackhammer speed" for a very short time.
If you think the problem is your shooter is out of balance it should be relatively easy to eyeball the system and see where it is not symetrical about the center of rotation
and to guesstimate the amount of weight you would have to add to the other side to balance it - like they do with the lead weights on car tires.
regarding metal fatigue, I dont think you will see any visable signs until something breaks. After a part has failed an experienced M.E. can look at the break and tell why it failed (crystalized, sheared, cut...)
  #24   Spotlight this post!
Old 10-24-2006, 09:40 AM
Unsung FIRST Hero
Rookie Year: 1996
Eugene
This is a good explanation but adding to this, the "A" scale is a frequency dependent curve that tries to approximate the inverse of human hearing sensitivity. As such it is less sensitive to areas where the human hearing is less sensitive. However, the offending noise is still there.
Many venues and outdoor arenas are now instituting noise level ceilings on performances. 110 dBA seems to be the defacto standard but the measurement is still an issue. Sounds decrease by the inverse square law with distance. So the issue is where do you measure the sound level. In arenas, it is acceptable to take an average of the seating area but any seat that exceeds the standard should be corrected by some means to come into compliance. Outdoor venues have to comply with neighborhood standards such that sound levels at the closest house must stay within local ordinance for the time of day. (local sound level ordinances vary between daytime and nighttime.) With a standard FRC playing field the drivers have less exposure than the judges and field people.
Al
WB9UVJ
www.wildstang.org
  #25   Spotlight this post!
Old 10-24-2006, 07:59 PM
LordTalps LordTalps is offline
Crimson Ninja
AKA: Pat
FRC #1885 (Robocats)
LordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to beholdLordTalps is a splendid one to behold
Send a message via AIM to LordTalps
Originally Posted by Greg Marra
To get back to the original question of "How Loud is Too Loud?".
This loud:
Just use common sense. If it sounds like something is going to break, try to find where the problem is and correct it before it is an issue.
*(not to scale)
QFT! Not like this is a football game where you've got to yell across a field.
I will not leave my account logged on to chiefdelphi again.
Cal Games Results Cory Off-Season Events 6 10-04-2004 12:42 AM
Cal Games Results Cory Off-Season Events 20 09-22-2003 08:45 PM
Congrats, Cal Games! Stephanie Off-Season Events 1 10-07-2002 05:05 AM
Cal Games Joe Ross Off-Season Events 18 10-04-2002 08:42 PM
Loud Music/Lots-o-Bass Clark Gilbert Chit-Chat 13 05-19-2002 01:22 PM
