Interacter Charger
There has been much of discussion about batteries and chargers. We know from experience that losing power in the last 30 seconds of a match is heart breaking.
We had read some of the great posts and ideas about keeping your batteries at tip-top shape. We also saw the post about chargers from Interacter. Seen here: http://www.chiefdelphi.com/forums/sh...attery+charger We did some research about the chargers and decided to buy the X5 model. It is a bank of 5 chargers all in one unit with just one power cord to plug in. http://www.batteryweb.com/interacter.cfm So far we are very happy with the unit. We will be putting it through its paces and give you and update. It can be found at: http://www.interacter.com/X5_page.htm I have also posted a picture of our setup. Feel free to ask any questions Team 27 Team RUSH |
Re: Interacter Charger
Just keep in mind the 2006 rule:
Don |
This charger setup is a 6amp. It is basically just a bank of five 6amp chargers with one power cord to worry about. From our research we think this charger setup will fit our needs nicely.
Thanks for the heads up though, some times rules can be missed when you see something new and exciting. Team RUSH |
![]() Last edited by eugenebrooks : 23-10-2006 at 22:30. |
This post points out how unlimited the power for robots has been. What First needs to do is limit the energy for our robots and make us think of energy management. Energy management and conservation are being forced on our country. May be they should be forced on our robots too.
I am curious.
What kind of current load does that put on the 120volt mains supply? In the unlikely event that it were to be charging 5 batteries at full current, it would be outputting 30 amps at 12 volts DC. I don't know what kind of efficiencies are involved with the rectifiers, but I'm guessing that the load on the mains is high. I'm just always mortified at the thought of blowing a breaker at a regional. It happens here at college from time to time, and the offending residents are usually heckled and picked on for killing power to their circuit. It's like some nerd faux-pas. I have no idea what kind of circuit protection is used at these venues. Which raises another interesting question- just what does a venues electrical bill look like during a competition? I doubt its a real problem, but I've always been curious about how much load we put on the pit electrical systems. Between the battery chargers, cordless drill batteries, laptops, drill presses and all the other power hungry stuff we use in the pits, its got to add up to something. -Andy A. |
As I have read over the X5, it actually is made up of 5 charging units and you have the choice of 3 different series.
The IC Series Industrial-Commercial 3-Stage + Desulfate. 20A to 30A The PS Series Professional - Series 3-Stage + Desulfate. 3A to 30A The LS Series Lineage - Consumers 3-Stage - 2.5A to 6.0A It's obvious that the IC Series isn't applicable or suitable for usage in FIRST. So the question is which of the other 2 series would you want and why? LS 12/6 or the PS 12/5 I'm thinking the LS 12/6 units within the X5, then maybe having one or two standalone PS 12/5 units for usage with "questionable" batteries. I like the idea of Desulfate, but I'm not sure it's worth it for all 5, and if the battery is really that questionable might it not be better to just replace it? Any or all feedback would be greatly appreciated. |
Technically, the difference between the PS and the LS series is in the state of charge indicator, a battery type switch, and the desufate unit, in addition to the different current limit. The desulfate unit is not very relevant to a gel cell that has a very low self discharge rate. Just charge the battery right after use, and always store it fully charged, and you will be rewarded with a long life. The desulfate unit is more relevant for flooded cells, and studies have shown an improved battery life in heavy use such as forklifts, but I have never seen any advantage on flooded deep cycle batteries used for sporadic trolling, but that is straying from the topic at hand. We test our batteries with a 20 amp load to 11 volts prior to every event, and our best battery is a 2004 battery at this point. This was just a good year for FIRST kit batteries, all of our batteries get good treatment. The battery type switch changes the adsorption and float voltage between values suitable for gel and flooded batteries. This would be more important if the battery were to be left on the charger for long periods, and proper gel settings do improve charger performance, but we only leave a battery on the charger overnight, and then store the battery. The led bar current gauge of the PS series would be nicer than the {full, >80%, <80%} indicators of the LS series, but we have not had to resort to batteries below the 80% level, so it has not mattered to us. The extra amp at a lower cost has been our most important factor. Eugene Last edited by eugenebrooks : 24-10-2006 at 03:11. |
-dave |
#10
I agree with Dave, above. We did purchase a 5 way charger that works well. A word of caution, as mentioned above the input current rises with a x5 charger as well the heat output. Allow plenty of free air to circulate around the larger charger especially at events.
#11
Thank you everyone for your input, knowledge, experience, advice and suggestions.
I've learned something new on this topic. The X5 may be out of our budget for right at the moment, possibly for this entire season, but likely I'll wait until after kick off to be sure, and then see. Thank you Everyone |
#12
but there is no need to order it prior to knowing the rules for a given year. We ordered ours near the end of the build period several years ago, and the vendor got it to us in less than two weeks. I would expect that would be the case now. |
#13
We totally agree about knowing what is in the KOP before buying items.
We give many presentations throughout the year and this will help keep our batteries charged for the long ones. Also, when we practice this should help keep up with the demand. We hate to waste precious practice time waiting for chargers to do their job |
| Need Batteries + Charger | AJ Quick | Electrical | 37 | 24-12-2003 16:16 |
| battery charger | archiver | 2001 | 3 | 23-06-2002 23:20 |
| Battery Charger | jgrater | Kit & Additional Hardware | 1 | 12-04-2002 14:14 |
| 6 Volt charger...? | kangarue23 | Technical Discussion | 7 | 12-04-2002 10:35 |
| Exide Battery Charger | jeffreym | Electrical | 2 | 25-03-2002 15:06 |
