Go to Post Or Dave could be messing with your head. - Daniel_LaFleur [more]
Unread 25-10-2006, 23:51
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Victor Brakes
Originally Posted by Alex698
I figure(correct me if you see errors), put a single-pole, double throw contact switch between motor, victor and leads to diodes then to a battery. By switching to the leads with diodes the motors are turned into generators by the forward motion of the robot. The diodes are so the battery doesn't back into the motors causing them to run at full.
I don't think you need the switch. There's some diodes in the transistors that will do the job. If all of the transistors are off, spinning the motors forces current into the supply.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 27-10-2006, 07:56
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Victor Brakes
I don't know if this thought will help, but what about regenerative braking?
Alex,
The speed controllers have this feature built in but using a slightly different method. The current supplied by the motor used as a generator is dumped into the transistors in the controller which are acting as a short. The controller is an "H" bridge design. Imagine the "H" with the motor connected from the center of the left vertical to the center of the right vertical. The top and bottom of each vertical is a set of power MOSFETs. The top of both upper vertical bars are connected to the positive battery connector and the bottom of both lower verticals is connected to the negative battery connector. To turn the motor on in one direction, the transistors in the upper left and lower right corners are turned on. To reverse the direction of the motor, the upper right and lower left transistors are turned on. To vary speed, you add a switching waveform to turn the transistors on and off, with speed determined by the ratio of the ON time to OFF. To provide braking, turn ON both of the bottom sets of transistors. Since they are both connected to the negative battery terminal, they are shorted together and that produces a short across the motor.
By varying the pulse that enables the brake you could vary the braking force. As pointed out by others in this thread, the braking is dependent on rotation. The slower the motor is turning, the less current is being developed in the motor, and the less effective the braking becomes.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 29-10-2006, 15:16
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: Victor Brakes
Originally Posted by xtolbert_gators
How do u hook a victor up so that you can reverse the polarity and cause the motors to stop. Could this cause a type of brake?Could there be a way to include it into the programming so that we can control it from the control board?
In the distant past (2000) we used a globe motor to rotate a set of forklift type arms from a stowed position. As the arms passed vertical, gravity would take over and the arms desended quickly. The globe motor was programmed to move foreward fast and then switched to a slow reverse to counteract the effect of gravity. The arms then continued to rotate forward but the action was less stressful on the mechanical parts. We have since learned that it is better to use springs to balance arms.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Brakes pakrat Technical Discussion 34 06-05-2006 11:45
pic: Brakes in action! falconmaster Robot Showcase 4 04-02-2006 12:57
Plants in my Victor? Rickertsen2 Electrical 1 23-10-2005 20:47
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Victor problems quickie25 General Forum 2 18-02-2004 19:51
