So, How do you shift?
Alright folks, I have a question for y'all. How do you shift gears at the operator station?
Do you use the buttons on the joystick? Do you use a switch on the control board? Do you use a switch that was custom mounted on the joystick? Or do you use something totally different? Any and all comments are appreciated. /dan |
Re: So, How do you shift?
Right trigger controls shifting. Left trigger switches between single and dual joystick control. Left top button rotates though the joystick translation profiles.
Right top button controls the ejection seat. ![]() |
Right Trigger to shift.
Originally it was left trigger, but right was better for me and left the left trigger for something else. ![]() |
i get in my seat, get comfy, buckle up for saftey ( i recommend it to everyone) put the key in the ignition, and as with every thing i have ever driven, i use the automatic transmission stick that is on my steering column, and shift into forward or reverse as needed, there is even an option for 2nd or 1st gear, but i really never use those
r thumb trigger
Team 294 will be using either a 2 or 4 speed transmission this year that will be controlled by encoders.
We are planning on using the triggers as manual overrides. If we have the 4 speed, we will automatically switch between 2 and 3 as the standard speeds and use the triggers to force it into high and low gear. But, this all depends on the game; We may cancel our plans for shifters if we don't need them. |
We use an on/off switch on the handle of the joystick. We cut a square hole in the grip portion (where your palm would normally go) so our driver never has to remove his hand from the prefered position he holds it at (which is towards the base of the joystick, resting his palm on the base at times). The reason we (I) prefer the on/off switch is that you can always look down and know what gear you are in. We had thought about using the trigger or a momentary button, but we could never be sure what gear we were in. Granted, you should know... unfortunately, however, in the heat of competition you never really can be sure of anything.
ofcorse you could have some leds to show what gear your in......heck you could make a HUD (heads up display for them......put them on the brom of a hat so you could see the or something......
joystick trigger.
#10
Also, I'm not sure about you, but I'm not a hat person. ![]() |
#12
we have an automatic or manual 4 speed. I believe we took the idea from team 33 killer bees. We use encoders to tell our pistons when to fire. this way we can determine the best shift points. Just in case the encoders go out we can switch to manual and we use 1 of the top buttons on the right to go up and one on the left to go down. We can also use either trigger to drop into 1st gear for pushing(or staying stationary better) or by pushing both triggers it goes into 1st gear and shuts off the compressor to give a little added power.
#13
On our interface last year we had three arcade style buttons labeled "Light Speed", "Ridiculous Speed", and "Ludicrous Speed". After our transmissions fried we didn't use them too much anymore.
EDIT: pic of our OI at nationals: ![]() Last edited by s_forbes : 10-31-2006 at 01:13 PM. |
#14
We've always just used the triggers. When we had the 4 speed (waste of time), we had the indicator LEDs light up on the OI to show what gear we were in. |
#15
On Team 340, we use the black joysticks. On these, there are two buttons per joystick. They are located on the top, and the other one is a trigger. We only use one joystick for the shifting, generally the right one.
| How do you shift?? | Mike Nawrot | Technical Discussion | 3 | 02-24-2006 06:54 PM |
| How did you control your Robot? 1? 2? Wheel? How? | ChrisCook | Control System | 9 | 05-17-2005 09:41 PM |
| How did you learn how to use Inventor? | Greg McCoy | Inventor | 26 | 05-24-2003 01:55 AM |
| Regional & Division winners, did you shift gears or not? | DougHogg | Technical Discussion | 34 | 05-02-2003 04:10 PM |
| To shift or not to shift? | sanddrag | Technical Discussion | 61 | 04-15-2003 10:56 PM |
