Go to Post Just remember: the tubes aren't a life saving device, the are a life CHANGING device! - Koko Ed [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 31-10-2006, 11:52
jamd jamd is offline
Junior Member
None #0180
jamd is an unknown quantity at this point
Exclamation [OCCRA]: Moving the basket... HELP!!
Dear fellow robotics competitors and/or OCCRA staff,
ok. so the JAMD robotics team is currently trying to devise a pneumatic system to lift the basket. we need the EXACT measurement (as close as possible) of the height of the bottom of the metal bar relative to the ground, the EXACT measurement (again, as close as possible) of the bar's diameter, and also the EXACT distance (...once again...) of the distance from the side of the metal bar to the side of the box.
Much Appreciated,
The "Varsity" JAMD Robotics Team
Unread 31-10-2006, 19:18
woody's Avatar
woody woody is offline
Too much metal for one hand! \m/
FRC #0033 (Killer Bees)
woody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to behold
Re: Moving the basket... HELP!!
I believe the bottom of the bar is about 27.5 inches above the ground. It has a 3/4 inch diameter. As for the last dimension, I assume you are talking about how far out from the basket the handle extends? if this is correct, then the dimension should be about 11 inches.
Run a search for the cad drawings; Im not sure where they are, but thats where all this info came from.
good luck
"The greatest of all mistakes is to do nothing because you can only do a little; do what you can." - Sir Sidney Smith
Unread 01-11-2006, 06:59
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Team Role: Coach
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
good luck
I second that one, it sounds right.
-Josh Murphy-
[OCCRA]: Basket? ZOMGLASERGUNS OCCRA 1 27-09-2006 18:41
pic: 1251 moving up in the world Billfred Extra Discussion 2 25-04-2006 18:11
[OCCRA]: what time is the occra banquet? MatthewArthur OCCRA 3 01-12-2005 17:28
[OCCRA]: After the first OCCRA competition ah27 OCCRA 7 27-10-2004 22:16
Moving the Nats. Date? roboTICKS-236 General Forum 4 19-03-2003 22:49
