Go to Post Glad to see the CIMulators aren't vaporware after all. - thefro526 [more]
View Poll Results: Should I go with a single stage, or multistage coil gun?
Single stage, keep it simple. 4 16.67%
Single stage is for wimps, go for multi!! 13 54.17%
I have no idea what the difference is. 7 29.17%
Voters: 24. You may not vote on this poll
  #16   Spotlight this post!
Unread 04-11-2006, 13:41
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Re: Solid core inductance
Originally Posted by X-Istence
200 volts is considered high? Pfft, 240 volts is the standard in european countries, with 440/480 used for Dryers. Enough to kill you? Sure, likely hood? Almost none. Ive shocked myself with 240 and 110. 240 just bites more.
The discussion is getting a little off track here.
If you've opened a computer power supply and looked at the component that Phil was thinking of modifying (before he found an alternative that makes it easier to design his inductor), you'll see that the cores are labelled with the usual "DANGER HIGH VOLTAGE" text and symbols. Those warnings are there for a reason.
And yes, 240VAC is the standard in Europe. You are statistically less likely to survive a shock from 240VAC than from 120VAC. That may be why the vast majority of european engineers adhere to standards of safe laboratory practice that make us, their American counterparts, look like a bunch of mad scientists.
Al is right -- 200 Volts is nothing to trifle with.
Richard Wallace
since 2003
  #17   Spotlight this post!
Unread 04-11-2006, 16:04
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Guys,
Just for the record, I have seen people get dead from these voltages. Why do you think they put all those stickers on appliances? There is an old pilots adage that can be applied here. "There are old electrical engineers and there are bold electrical engineers. There are NO old, bold electrical engineers! One of my instructors on the first day of AC electronics class told us this...
"Learn to identify people who do not have respect for exposed voltage. Stay away from them for when they go, they take others with them." If you don't think (and believe) that 120 volts is high voltage and lethal I can have a couple of hundred electricians and linemen convince you otherwise. Do you know why the International Brotherhood of Electrical Workers was formed in 1894? Because the average life expectancy of an electrician was 34 years of age due to working with line voltage.
Al
WB9UVJ
www.wildstang.org
________________________
  #18   Spotlight this post!
Unread 04-11-2006, 19:36
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
But you have to realize that although this is a high voltage system, the amperage is far less then the electric coming from your outlet.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
  #19   Spotlight this post!
Unread 04-11-2006, 20:14
Rookie Year: 1996
While you are correct that a wall socket can deliver more current (typical breaker rating is 20A), it takes far less than that to kill a person.
Look here (you brought up Wikipedia earlier in this thread) for more on the physiology of electric shock.
You also said earlier that you have two capacitors of 500 uF each.
200 Volts x 1000 uF = 0.2 Coulomb, enough electric charge to deliver a peak electric current of 200 milliAmperes to a 1000 Ohm load; your body, for example, might be represented by about this resistance, depending on ambient humidity and how sweaty you are. That current will decay with a time constant of 1 second. Delivered to one hand while the other hand is on the return path, that current pulse is sufficient to put your heart into ventricular fibrillation. Of course you might be lucky and not present such an ideal circuit path to your heart on the first try, but your luck would not hold out forever if you kept trying again and again.
I strongly urge you to read up a bit more, and not to attempt experimental verification of the analysis above.
Richard Wallace
since 2003
  #20   Spotlight this post!
Unread 04-11-2006, 23:11
[527]phil's Avatar
Alumni
AKA: Phil
Which is the exact reason i use the one hand rule. I only work on the circuit while it's charged with one hand, the other is in my pocket.
  #21   Spotlight this post!
Unread 05-11-2006, 09:34
Unsung FIRST Hero
Rookie Year: 1996
That is an excellent start!
I have to ask why you are not using a linear power supply to charge up the caps. It seems like an easy way to accomplish a 200 volt source.
Al
WB9UVJ
www.wildstang.org
  #22   Spotlight this post!
Unread 05-11-2006, 14:27
[527]phil's Avatar
Alumni
AKA: Phil
Well mainly because the power supply i have is a kit I built a few years ago, and only goes up to 12 volts. But the main reason is i want to be able to finish the coil gun and know that i made it from "scratch."
That, and the fact that i need to drag my presentation out to a full 40 minutes, so I'd rather go through the formulas, and show how the boost converter works rather then just say "well this power supply charges the caps". But yes, using a power supply would be MUCH easier, but just ask my mentor, "easy" is not in my vocabulary
  #23   Spotlight this post!
Unread 05-11-2006, 14:41
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Originally Posted by yongkimleng
You're making something I can only dream of! Haha..
In gaming terms its called a Railgun I suppose.
Railguns are slightly different from coilguns. In a coilgun, coils of wire around the barrel are used to pull the projectile down the barrel. A railgun uses two rails which the projectile slides down. In a railgun current passes down one rail, through the projectile and back down the other rail. Railguns have the advantage that they accelerate the projectile evenly down the entire length of the barrel. To do this, a coilgun would require multiple stages.
railgun
1139 Alumni
  #24   Spotlight this post!
Unread 05-11-2006, 15:22
[527]phil's Avatar
Alumni
AKA: Phil
But with each stage comes more complications. I think i will make a multi stage and a single stage. A multistage requires 1 capacitor bank PER coil. They also require an IR detector system to trigger the next set of coils(unless you can figure out the excact timeing, which is almsot impossible). But despite which kind i build, first i need to get the boost converter working, once thats working everything else is easy to make. It'll also give me a chance to use one of those PIC microcontrollers i have
  #25   Spotlight this post!
Unread 05-11-2006, 16:03
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Would a voltage multiplier work??? Abeit, I have no idea if that type of design would applicable since it's a high voltage and low current device.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
  #26   Spotlight this post!
Unread 05-11-2006, 16:39
Unsung FIRST Hero
Rookie Year: 1996
The simplest thing to do in this situation would be to get a line operated high voltage transformer with a secondary winding of 300 volts center tap. (I am guessing right now at the numbers) In a full wave rectifier, you might be able to get 200 volts DC to charge the caps or to fire the energizing coil. Transformer cost in the $50 + range new, total supply less than $100 (fuse, line cord, diodes and trerminal strips). This is a common transformer in tube type equipment and might be found in a junk TV or radio or at a Hamfest.
What Phil is trying to make is what some people call a "whistler supply". It uses a low voltage DC power source like a bank of batteries, running an oscilator to produce an AC voltage capable of driving a low voltage primary winding on a transformer. The secondary winding is a high voltage winding much the same as the linear supply described above. The difference is the transformer core. At 60 Hz you need a lot of iron to couple from the primary to secondary windings. At 1.5 kHz or above, the core becomes more efficient and so the need for a heavy iron core is diminished. MOst often these supplies are actually running at much higher frequencies like 10-15 kHz. When they operate, the supply can be heard as whistling. This type of supply is comon in a camera photo flash unit when first turned on. Since you need an oscillator and high power driver (sometimes the same device) this is a much more complex device. The upside is the transformer is a fraction of the weight of a line operated supply. However, 200 volts is still 200 volts regardless of how you get there.
High voltage batteries were plentiful at one time when portable radios were tube operated. Finding them now is next to impossible.
Al
WB9UVJ
www.wildstang.org
  #27   Spotlight this post!
Unread 05-11-2006, 17:01
Rookie Year: 1996
... But despite which kind i build, first i need to get the boost converter working, once thats working everything else is easy to make. It'll also give me a chance to use one of those PIC microcontrollers i have
The boost converter is a fun project in its own right. Learning to build switch-mode power converters is worth the time spent. I'm a little biased here; switch-mode power converters were one of my earliest projects (after audio amplifiers) a couple dozen years ago when I was getting started in electronics.
However, if you just want to charge capacitors, a simple charging circuit using a 115VAC line cord, a full-wave rectifier, a couple of resistors (one in the 50 to 100 Ohm range in series with each capacitor for current limiting, and another in the 100,000 to 200,000 Ohm range across each capacitor to bleed off the charge when it's not in use) and a suitably rated, insulated switch for each capacitor you want to charge would do the job nicely, if you can make the coil gun work with about 170 Volts dc on each capacitor.
If you need higher voltage, or if you need to adjust the voltage to control the gun, or if you just want the fun of building a switch-mode circuit, then go on ahead with the boost converter.
Also, if you are planning on a multi-stage gun with each stage fed from its own capacitor, you will probably want to have a separate voltage measurement circuit for each capacitor so you can tell when they are charged.
Insulate all the high voltage connection points well with electrician's tape or heat shrink tubing. If you plan to demonstrate the device (and why else would you build it?) then it's a good idea to enclose everything in a non-conducting project box after you get it working. And, yeah, keep one hand in your pocket while the circuit is live.
Stay safe and have fun.
Richard Wallace
since 2003
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
is it a solid or a fluid? John Gutmann Technical Discussion 11 05-08-2005 01:05
Armored Core 3 AC Designs/Reviews MarkF Chit-Chat 4 24-05-2003 18:13
solid edge solid works ceileachair Inventor 1 21-01-2003 22:03
Are you hard core or not? Joe Johnson Championship Event 7 25-04-2002 23:05
