Go to Post I hope Dave doesn't see these. He'll want you to put in a banana and use it for a game clue. - IndySam [more]
Go Back   Chief Delphi > Other > VEX
Unread 05-11-2006, 15:12
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2007
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Vex SquareBot- movement programming problem
Hi, I'm programming the Vex SquareBot in MPLAB IDE, and am having some problems programming the movement since one of the motors on the SquareBot is inverted. I tried this code:
Code:
void normal_operation()
	int R_Joy_Up    = 127;		// These hold the joystick values.
	int L_Joy_Up    = 127;		// Only R_Joy_Up & L_Joy_Up are used in tank mode.
	int R_Joy_Down  = 127;		// This probably isn't really needed, to be cleaned up after project completed.
	int L_Joy_Down  = 127;
	int R_Joy_Right = 127;
	int L_Joy_Right = 127;
	int R_Joy_Left  = 127;
	int L_Joy_Left  = 127;
	int temp;
	while(autonomous != 255)
		R_Joy_Up = GetRxInput( 1,2 );
		L_Joy_Up = GetRxInput( 1,3 );
		if(L_Joy_Up > NEUTRAL)
			temp = L_Joy_Up - 127;
			L_Joy_Up = NEUTRAL - temp;
		else if(L_Joy_Up < NEUTRAL)
			if(L_Joy_Up <= 0)
				L_Joy_Up = 253;
		autonomous = GetRxInput(1,5);
		drive ( R_Joy_Up, L_Joy_Up );
		PrintToScreen ( "L_Joy_Up: %d\n" , (int)L_Joy_Up );
		Wait(1);
My code works fine, until I move the left joystick on the vex controller all the way to the bottom. The the motor suddenly reverses direction
Does anyone have any suggestions? I really appreciate the help
Thanks,
Nathan
Help needed with coding simultaneous movement (EasyC/VEX) bodaciousllama Programming 7 14-08-2006 17:35
pic: Virtual Squarebot petek Extra Discussion 22 09-05-2006 16:01
C programming problem... wasabi824 Programming 5 08-02-2004 01:04
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
programming problem gthakore Programming 16 20-04-2002 12:21
