Go to Post If you promote not only the growth of your own team but of other teams at other schools you are successful. - Koko Ed [more]
Unread 05-11-2006, 23:16
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Lightbulb First controller out of VEX
Hey all,
After looking at the field controller used in the last SCRRF and Cal Games, I came up with an idea! Why don’t I build a VEX field controller just like the one I saw for team use and for kicks? But in the process of brainstorming, I thought of a potential problem. Looking at the VEX controller used at Cal Games, it looked like the custom circuit board had some resistors and a few diodes on the board. What were they used for? Is it not safe to pump +5V into the competition port? Well, another question to ask, how would you complete the circuit between the ground and autonomous pin using the VEX controller without relays?
Thanks!
VEX radio controller Greg Needel FIRST Tech Challenge 3 06-05-2007 15:09
Hooking up a motor to Vex controller Jeremiah Johnson VEX 2 15-08-2006 19:36
IR on the Vex controller? jgarbers FIRST Tech Challenge 0 18-04-2006 14:07
Programming VEX Controller HRobotics Programming 4 21-03-2006 23:25
Robot Controller Flips Out Eko Programming 6 22-02-2004 22:53
