Go to Post When there appears to be something stupid wrong with a game (HPs outscoring robots, unreliable loading, autonomous that accomplishes nothing) I shouldn't complain about it. I should see it as a challenge to exploit! - Chris is me [more]
Unread 08-11-2006, 23:35
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Exclamation IR Emitters and Receivers
Hey guys, Brand new.. out of the package me ok .. im sorta new to programming ... but not really ANyways.. i'll get to the point
I heard that last year there were two beacons of IR Emitters. My question is, How far can the IR receiver aquire a signal from? and how do u set up a IR receiver>??
I had computer engineering last year but they didnt have that unit (even tho they had the parts ) If you could help me out that be great
Unread 09-11-2006, 23:50
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: IR Emitters and Receivers
I think the last time IR beacons were used was a couple of years ago. I seem to recall them having some problems with unintended reflections on the real game floor that were difficult to simulate on a practice field. IR reflects very well, as you can demonstrate by pointing your TV remote control at a wall directly opposite the television.
I believe the receivers that were used were similar to the PNA4602m... they receive and demodulate a 38kHz pulse from the emitter. When it is present they set their output pin low (or is it high) and vice-versa. This makes it really easy to read... it is either receiving or it is not. If you hook up a PNA4602m to a PIC chip and drop some fairly simple code into it you can read the output of a TV remote control (I use the Sony IR protocol) for just a couple of bucks.
The IR emitters have since been replaced with visible beacons and the CMU2 camera.... but who knows what they have dreamed up for this year....
Good luck, and have fun,
Jason
Unread 10-11-2006, 09:33
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I believe he was referring to last year's photoswitches, which used IR. There were two included in the kit, one unit was just a reciever while the other unit was a transmitter/reciever. There are some other threads on CD about specifics on how to wire it. Essentially, as the name suggests, it just turns on or off in response to a signal (IR). I believe the spec sheet said the range is good for several feet, but that depends on the application. You can get more range if using the sensor in a beam breaking type application. If you are using reflected IR the range is shorter, depending on what your are reflecting off of.
Unread 12-11-2006, 01:07
AKA: !!Mitch!!
FRC #1392
umm..the reflecting part... if it was reflected off a spinning mirrior... would it lose the insensity of the beam?
Unread 12-11-2006, 01:31
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
What is the problem you are trying to solve?
these may not be the best solution, so could you fill us in on what you have to do?
Unread 12-11-2006, 13:02
AKA: Dan
As mentioned before, the IR sensor is pretty sensitive. Last year we used our sensors to detect wheel speed of our shooting wheel by just using a little white paint. Also the sensors have a built in gain adjustment to change sensitivity. No sweat they are easy!
Unread 13-11-2006, 16:30
AKA: !!Mitch!!
FRC #1392
basically .. i have 4 ir receivers on a 2 inch by 2 inch wood platform... a motor is gonna to be spinning at a constant speed, with a certain rpm... the mirrior is then connected to the motor and is angled at a 45 degree angle..... the program is going to design a logitcal "play field" .... so it noes where its surrondings are... again . i ono if this is possible .... or programmable... also ... by the loooks of it ... ir isnt gonna be popular as much as the cam this year..
White Paper Discuss: Controller Circuit- Infrared Emitters CD47-Bot Extra Discussion 1 13-02-2004 17:48
Ordering the TSOP34840 Infrared Receivers yaman Electrical 5 23-01-2004 02:10
IR Receivers mounting Atheist Electrical 3 19-01-2004 11:29
IR Receivers and Controller Teedoff101 Electrical 2 11-01-2004 21:02
Pressure gage on receivers tareyton Pneumatics 2 18-02-2002 21:14
