Lightweight Aluminum Vex Metal Kit
Just noticed this:
The Aluminum Kit consists of the following aluminum parts: (4) C-Channel CHAN-121-25, (1) C-Channel CHAN-151-25, (2) Flat Plate PLATE-5-25, (1) Medium Chassis Kit CHASSIS-25x25x2, (4) Bar 1x25 BAR-25 Price: $99.99 The parts are competition legal. According to my calculations if these items were purchased seperately in their normal non-aluminum version it would total $52.88. As far as I can tell only the parts in this kit are available in aluminum, and they state "Aluminum parts are available only as a kit and are not sold individually." I'm happy they've introduced lighter weight parts, but upset they're done so in such a restricted manner. A large size chassis made of aluminum would be nice. Last edited by nonother : 09-11-2006 at 20:59. |
Re: Lightweight Aluminum Vex Metal Kit
I saw that and really liked it!
But at $100, that is mighty expensive aluminum, especially for VEX. I think the price will scare off, rather than attract, potential customers. |
Regardless, I still believe you'll see a lot of this on the field, particularly on manipulators. Think about the weapon of choice for Half-Pipe Hustle: the tilting tank tread loader. (Definitive example in Orangeburg: FVC 171) Many of those devices required a lot of metal to make 'em sturdy. Cut that weight down, and you're suddenly capable of lifting the same balls up to the goals even faster (or lifting more balls at the same performance level, to the extent that the sizing box will allow). This year, since you've got so many field elements, I see teams trying to figure out how best to use their motors and servos to accomplish the widest variety of functions that they safely and reliably can. If you can make a mechanism work on one motor where it once worked with two, you leave the door open for a mechanism elsewhere. (Monkeybot, anyone?) |
| vEx Custom Metal Kit? | thefro526 | FIRST Tech Challenge | 3 | 31-08-2006 20:30 |
| Type of Aluminum used in kit frame | Epot86 | Kit & Additional Hardware | 10 | 29-01-2006 22:29 |
| VEX EDUbot hybrid or $50.00 VEX kit? | Tazlikesrobots | Robot Showcase | 15 | 13-08-2005 22:12 |
| Where to get lightweight flexible coupling? | sanddrag | Technical Discussion | 3 | 20-01-2005 01:22 |
| precision grade aluminum extrusion - item MB Kit | Loren 930 | Technical Discussion | 2 | 11-01-2002 21:42 |
