Go to Post Our safety manager isn't allowed to use the power tools, because he used a drill as a pointing device. - daniel_dsouza [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 25-11-2006, 23:52
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Lagrange Multipliers
Ok, I'm having a problem understanding a question about Lagrange Multipliers.
Given the function f(x, y) = 16 − x2y2 and the constraint (x − 1)2 + (y − 1)2 = 4, find the maximum and minimum.
I've reduced it to the system:
  1. -2x = λ∙2x
  2. -2y = λ∙2y
  3. (x − 1)2 + (y − 1)2 = 4
There are a few ways to solve this:
  • Assume λ = -1, which gets you nowhere
  • Assume x = 0, for which y = 1 ± √3
  • Assume y = 0, for which x = 1 ± √3
I know that the real answer is when x = y, but I can't get that going forwards.
Anyone have suggestions as to how to approach it?
Unread 26-11-2006, 00:50
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Lagrange Multipliers
1. and 2. of your system are incorrect. The left hand side is correct, but the right hand side is wrong. What is the derivative of (x-1)^2 with respect to x? Ditto (y-1)^2 w.r.t. y. You might try fully expanding the expression and then deriving it if you're still getting 2x and 2y.
Hint: The chain rule always applies in derivatives, everywhere, all the time.
Unread 26-11-2006, 01:12
AKA: Jamie Bliss
Darned me and those shortcuts. I didn't think the constant offset would change it much.
Ok, it doesn't. Just 2(x - 1) instead. It's always the little things.
All these time multipliers.... archiver 2001 0 24-06-2002 02:53
Multipliers (SC6 and SC7) archiver 2001 2 23-06-2002 22:43
How do multipliers combine??? archiver 2001 2 23-06-2002 22:40
