Go to Post Without compromise, engineering would be boring. - Mike Betts [more]
Unread 27-11-2006, 09:09
nmihailidis nmihailidis is offline
nmihailidis is an unknown quantity at this point
SF and RM
Hi everybody.
I bought CMUCam2 and I want to ask you two questions.
Firtst, when I am sending the 'SF' command, is there a way to see the form of F-packets and make the non-visible ASCII characters visible?
Second, what means raw bytes packets? I can't understand the meaning from the manual. Can you give me an example of raw modes?
I would appreciate any help.
Thank you in advance..
NM
Unread 27-11-2006, 10:21
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: SF and RM
if you want to look at some good code for the camera look at kevin's code (www.kevin.org/frc). His code is great, even if you don't use it.
Eric Haskins KC9JVH
Unread 27-11-2006, 12:04
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: SF and RM
Kevin Watson also has the PDF datasheets that have alot of info. Ill pull out my CMUCam and see if i can answer your question.
Unread 27-11-2006, 18:52
divergentdave divergentdave is offline
FRC #1816 (Green Machine)
Rookie Year: 2007
divergentdave is a jewel in the roughdivergentdave is a jewel in the roughdivergentdave is a jewel in the rough
Send a message via AIM to divergentdave
Re: SF and RM
Take a look at this thread for more about the format of SF packets.
http://www.chiefdelphi.com/forums/sh...ad.php?t=48821
Team 1816 - The Green Machine
Unread 27-11-2006, 23:19
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: SF and RM
A theoretical ASCII packet would look like this:
Code:
X 54 42 35\r
While the equivalent Raw mode packet would be:
Code:
X\x36\x2A\x23\r
It allows you to write simplier serial drivers because each byte is the value, not some character that represents a part of the value.
Bill of Materials, do it and do it well, and bring it to your event sanddrag Rules/Strategy 3 24-03-2006 21:09
Thank you 1359 and 1569 and Congrats 492, 1595, 604 SilverStar Thanks and/or Congrats 0 13-03-2005 23:21
pic: Stars and Stripes over Einstein and Galileo CD47-Bot Extra Discussion 6 01-05-2004 00:54
