Re: What language do you use?
Robotics: C
General Purpose Embedded: C Fast Routines: Assembly School: Java Calculator: TIbasic and C (yes, there is a compiler) Quick/Dirty Interfaces and I/O: VB6 (NOT .NET), C++, or QB -Q |
Robotics: C
Most other things: Ruby Learning C# though as a sort of middle-ground. |
Robotics: C
Simple Programs: C+ (Yes, C and C++ mixture. If you can call it that) Complex Programs: C++ Web Development: PHP, SQL (MySQL), XHTML, CSS, Javascript Low-Level (Such as OS-DEV): x86 ASM School: Java (which I used to hate with a passion; not so much anymore) Among other things... SX Assembly for the SX52 Microcontroller (Crazy thing, 80MHz! You can write a video kernel in it - software black and white NTSC :-) ) And I've experimented with many C-based scripting languages. |
C#
MICRO32 , for low-level h/w bit pushing projects
MACRO32, for assembler level BLISS for high level... Of course my first "electronics" class in high school votech did involve 6.3VAC and filaments.... But seriously, any programming language can be used... it is how you use it that counts as long as the resulting run-time execution profile, code size, or data space used doesn't put you at a disadvantage over some other language or tool. Personally, I always look at the assembler generated by the compiler to see if I'm using things correctly to match the processor architecture. If a line of C code is compiled into 30-40 instructions, then I probably didn't choose the best programming method for solving the problem. For example, in one piece of code I just finished I needed to walk an array and move all the entries up one until some end condition. Putting the code in a loop looked good in C - nice and compact - until I looked at the compiled code. It took some 196 cycles on average to do all the array indexing computations, move the data around, and do end condition check for just 2 array entries with the for loop. In contrast, unwinding the for loop across the whole array array[0] = array[1]; array[1] = array[2]; ... takes only 64 cycles to always move the whole array even though its like 8-10x more C code. The particular chunk of code started life as a singly linked list structure, but computationally it was just too expensive in terms of compiled code size and execution time. Building a lookaside/ordered index table as a companion to the data structures was much more effecient on the current processor in this case. The argument of using oop or this or that os is often moot - none of those run very well at all on the current architecture. Moving to a processor that does run linux, say, still doesn't begin to address the issues introduced by using a full blown os; namely no pre-emptive scheduling and very long latency issues in terms of use within a real-time system such as a robot. Yes, there are flavors and changes you can make to get linux to almost be rtos capable, but that typically means either throwing some serious h/w at it or reduction of kernel services to something that means you're really not running linux but some strangled subset there of. The flip side is learning to program well with an architecture that is both powerful and weak at the same time. The test of learning to program well is capitalizing on the PICs strengths while recognizing and avoiding its weaknesses as much as possible. If you can do this using some other language or interface - great! Go for it! But for now, I'll stick to C and EasyC as both put me only at a slight disadvantage over assembler if the proper programming method is found and utilized. Bud Last edited by dcbrown : 30-12-2006 at 15:00. |
For the robot I code in C. Last year, we started a dashboard in VB.NET (that was the main language that my friend and I knew) but eventually converted over to C# after discovering dashboard code that already had most of the work done on it (it was posted on ChiefDelphi somewhere).
Personally, I used .NET for a while, but I found that everything Microsoft makes for development products (that is worth using that is) is very expensive. I do like the express editions of .NET 2.0, but they are somewhat limiting, especially SQL Server Express. For a job I was doing last year I was forced to switch over to PHP running on an Apache server with a MySQL database backend, and it was so much less restrictive than Microsoft, it was free, and it was more logical I found. I ended up switching my hosting from Microsoft Hosting (on IIS ) to Linux Hosting (on Apache). |
Personally, I always look at the assembler generated by the compiler to see if I'm using things correctly to match the processor architecture.[/quote]
Not to sound like an idiot, but how do you do this? I know assembly language quite well, but I never really found an application for it in practical programming. Is there a way to do this in FRC programming as well? |
Use the list file. It's optionally generated by the linker.
In MPLAB IDE, View->Disassembly Listing or View->Program Memory.
If using Program Memory view, I select the "Symbolic" tab at the bottom of the window. For example, Code:
void EventHandler_Remove( void )
unsigned char ndx;
for (ndx=0; ndx<MAX_EVENT; ndx++)
EV_Links[ndx] = EV_Links[ndx+1];
if (EV_Links[ndx] == 0xFF ) break;
return;
Code:
526: for (ndx=0; ndx<MAX_EVENT; ndx++)
6002 6ADF CLRF 0xfdf, ACCESS
6004 0E10 MOVLW 0x10
6006 5CDF SUBWF 0xfdf, W, ACCESS
6008 E21D BC 0x6044
6040 2ADF INCF 0xfdf, F, ACCESS
6042 D7E0 BRA 0x6004
527: {
528: EV_Links[ndx] = EV_Links[ndx+1];
600A 28DF INCF 0xfdf, W, ACCESS
600C 6AEA CLRF 0xfea, ACCESS
600E 0FE0 ADDLW 0xe0
6010 6EE9 MOVWF 0xfe9, ACCESS
6012 0E07 MOVLW 0x7
6014 22EA ADDWFC 0xfea, F, ACCESS
6016 50EF MOVF 0xfef, W, ACCESS
6018 6EE6 MOVWF 0xfe6, ACCESS
601A 50DF MOVF 0xfdf, W, ACCESS
601C 6AEA CLRF 0xfea, ACCESS
601E 0FE0 ADDLW 0xe0
6020 6EE9 MOVWF 0xfe9, ACCESS
6022 0E07 MOVLW 0x7
6024 22EA ADDWFC 0xfea, F, ACCESS
6026 52E5 MOVF 0xfe5, F, ACCESS
6028 50E7 MOVF 0xfe7, W, ACCESS
602A 6EEF MOVWF 0xfef, ACCESS
529: if (EV_Links[ndx] == 0xFF ) break;
602C 50DF MOVF 0xfdf, W, ACCESS
602E 6AEA CLRF 0xfea, ACCESS
6030 0FE0 ADDLW 0xe0
6032 6EE9 MOVWF 0xfe9, ACCESS
6034 0E07 MOVLW 0x7
6036 22EA ADDWFC 0xfea, F, ACCESS
6038 50EF MOVF 0xfef, W, ACCESS
603A 08FF SUBLW 0xff
603C E101 BNZ 0x6040
603E D002 BRA 0x6044
530: }
531: return;
6044 D005 BRA 0x6050
Code:
EV_Links[0] = EV_Links[1];
EV_Links[1] = EV_Links[2];
<snip>
EV_Links[15] = EV_Links[16];
return;
533: EV_Links[0] = EV_Links[1];
6046 C7E1 MOVFF 0x7e1, 0x7e0
6048 F7E0 NOP
534: EV_Links[1] = EV_Links[2];
604A C7E2 MOVFF 0x7e2, 0x7e1
604C F7E1 NOP
Bud |
#10
C - Robotics
C++ - most x86/x86_64 stuff assembly - small PIC projects English - general human interaction David |
#11
c & asm -> FIRST
Java -> most complicated projects Basic 6.0 -> Simple apps for testing purposes Basic .NET -> Refigned version of above C++ -> DirectX LUA -> Gmod (hey its a language) I would really like to see the Java TinyVM used on the FRC, but thats just a dream. |
#12
#13
I use C mostly. I want to learn an interpereted language, but haven't invested the time to learn one. Ruby sounds cool from what my brother has done with it. He created a simulator that takes input from the OI dashboard to drive a robot on the screen rendered with OpenGL.
I also use GTK+ under Linux for graphics. I have been using latex for typesetting. It is a programing language specifically designed for making nicely formated (math or english) papers which are compiled into pdf and ps files for viewing. |
#14
I would say Python all the way for an interpreted language.
The other day one of the programmers on my robotics team was asking about how to check if his joystick curve function was working. I was able to rewrite a prototype function in a python editor, stick a for-loop at the bottom the file, and run it, all in about 1-2 minutes (he was still explaining to someone about how it would or wouldn't work when I finished). The really nice thing about Python is that it has hundreds of *useful* library functions, especially in the string and math realms. It has native BigInt support, and much else. One problem is that it has no strict typing. This can also be a huge benefit if you are trying to use code intended for one thing for a completely different purpose. I actually learned python as a scripting language for Vega Strike, but I'm so glad I know it now. Perl feels less "right" than python... too much syntax, and not enough sense to it. Also, I would say C++ for best compiled language... It has a pretty nice library of functions, it's native, and it runs all C libraries with few hassles. It has some methods for garbage colleciton, and a lot of other features that make it really generous for a compiled language. Speaking of C++, I've heard Objective-C (I've never used it however) is a nice language (though it hurts my eyes to look at it). It supposedly now has garbage collection support, yet it's compiled. I wonder how they did that... Java and PHP are okay... but they feel messy. I used to really like PHP for web development, but I learned about Django which is a much more structured web development method written in Python. |
| What sensors do you use? | StevenB | Programming | 18 | 06-04-2006 23:33 |
| Drivetrain, what did you use? | maclaren | Technical Discussion | 42 | 15-02-2004 21:09 |
| What view do you use? | Brandon Martus | CD Forum Support | 10 | 02-12-2003 17:32 |
| What do you YOU use your bins for? | AlbertW | General Forum | 40 | 13-04-2003 04:18 |
| What Foreign language did/are you taking in High School? | Tom Fairchild | Chit-Chat | 34 | 31-07-2001 21:00 |
