Go to Post canadians are amazing.. - Ashley Christine [more]
Unread 28-11-2006, 15:05
1strobotixrox 1strobotixrox is offline
super cool :)
AKA: Megan
FRC #2104 (South High Robotics)
Rookie Year: 2007
1strobotixrox is an unknown quantity at this point
Send a message via AIM to 1strobotixrox Send a message via Yahoo to 1strobotixrox
What language do you use?
Hey, my team is new, so i was just wondering what programming language you guys use. I've heard of C, C++, EasyC, and Java. Which is best? Personally I know a little Java, but I haven't really heard good things about it on the forums.
-Thanks
Unread 28-11-2006, 15:24
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: What language do you use?
well depends on what Im doing . . robot coding I use C,
I/O programing on my PC I use C++,
any thing that I want to look "pretty" I use Java,
and I use ruby when I just want it done.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
C and EasyC are the two that FIRST provides teams with, and that there is default code written for (I think there's default code for EasyC...).
I thought C was relatively easy to learn, and for what you're doing on the robots it can be done without getting horridly complicated (it can get complicated, but you can do all the basic things and alot of advanced ones without it being too hard).
If anyone ever got courageous they could program in assembly too, but I don't imagine that being all that enjoyable.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 28-11-2006, 15:39
theycallhimtom theycallhimtom is offline
AKA: Tom Conerly
FRC #1540 (The Flaming Chickens)
theycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura about
Send a message via AIM to theycallhimtom Send a message via MSN to theycallhimtom
For robotics I use C.
For school I use Java.
For most other projects I use Python.
Unread 28-11-2006, 15:46
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
EasyC is great for beginners, as it is easy to understand and it shows you the code it generates as you go (so hopefully the programmer will learn along the way).
C is a very good language to use for the types of applications seen in FRC. Compared to C++ and Java, it is a very "light" language which still has all of the functionality you will need to program your robot. This is important since the IFI Robot Controller that you get with the kit of parts doesn't have too much processing power or memory in comparison to your personal computer. As far as I know, C is the standard in embedded-level programming.
As far as C++ and Java go, you will get lots of different opinions. I personally prefer C++ because there are lots of things you can't do in Java that you can get away with in C++. The downside is that it's easy to write code that breaks! I use C++ for both school and my own projects.
Java, on the other hand, sort of forces you to be a better software developer by taking care of memory management and providing plenty of built-in libraries to use. Java is also not dependent on any specific operating system, so a lot of companies use it to make their software more versatile. So far I have really only used Java for school, but at my next co-op job I'll be doing software development using Java.
Andrew Neilson - Team 772 Alumnus
University of Waterloo Computer Science, Class of 2010
Unread 28-11-2006, 16:37
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
Robot Development - C18 and ASM (to speed up interrupt handlers)
Desktop/Server Development - C# and .NET 2 or VC++ 8
Mobile Development - C# and .NET Compact Framework
Unread 28-11-2006, 16:52
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Sounds like me.
Except ASP.net 2 for web development.
Eric Haskins KC9JVH
Unread 28-11-2006, 16:59
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
C for robotics
Java for school
Whatever i feel like messing with for all other projects
Unread 28-11-2006, 17:49
GRaduns340 GRaduns340 is offline
The Fruit Man
AKA: Gary
FRC #0340 (Greater Rochester Robotics)
GRaduns340 has a spectacular aura aboutGRaduns340 has a spectacular aura aboutGRaduns340 has a spectacular aura about
Send a message via AIM to GRaduns340
Although I'm not programmer for our team, we use C for the robot.
I use Java for school and some other projects.
PHP and MySQL for most of what I do (web development)
Unread 28-11-2006, 17:56
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
C - robotics
Java - school
C++ and/or Java - other stuff
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 28-11-2006, 18:21
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
FRC #0254 (The Cheesy Poofs)
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I use:
For robots - C
For school - C++
For work - PHP, Delphi
For OS development - ASM
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 28-11-2006, 19:40
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Here's what i use various languages with.
C = robotics. It's hardly ever used anywhere else.
C++ = for fun. Since my school dosen't have a programming class, i dont use it at school. I just use it to make random stuff at home.
Java = website programming, usually. Java is often used online.
There are also various other languages out there. Many can do the same thing. As far as robotics is concerned, knowing C is enough.
Unread 29-11-2006, 06:37
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
C++ and C# are my two main languages.
Unread 29-11-2006, 06:46
Joel J's Avatar
Joel J Joel J is offline
do you..
Rookie Year: 2000
Joel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond repute
I use C for FIRST. I don't like EasyC.
PHP -- web
C++
There are a few others, but they aren't used frequently enough.
Joel Johnson
Division By Zero (229) Alumni, 2003-2007
RAGE (173) Alumni, 1999-2003
  #15   Spotlight this post!
Unread 29-11-2006, 22:59
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Python, when I have a choice.
What sensors do you use? StevenB Programming 18 06-04-2006 23:33
Drivetrain, what did you use? maclaren Technical Discussion 42 15-02-2004 21:09
What view do you use? Brandon Martus CD Forum Support 10 02-12-2003 17:32
What do you YOU use your bins for? AlbertW General Forum 40 13-04-2003 04:18
What Foreign language did/are you taking in High School? Tom Fairchild Chit-Chat 34 31-07-2001 21:00
