Go to Post Why follow when you can lead? - Elgin Clock [more]
Unread 29-11-2006, 14:03
Guy_E Guy_E is offline
FRC #1574 (MisCar)
Team Role: Leadership
Guy_E has a spectacular aura aboutGuy_E has a spectacular aura about
Send a message via MSN to Guy_E
Problems with the Gyro
Hi,
I started to learn how to use the gyro. I downloaded Kevin's code from the internet and tried to use it. There are some things which I haven't understood completely.
I tried to print the variable "gyro_rate", but its values were between 1800-2200.
Shouldn't it be much lower? Shouldn't this variable be measuring the angular velocity in (radians/seconds)? I don't know if there is something wrong with the code, or something wrong with my understanding. I then tried to print the value from the function Get_Gyro_Angle(), but again, the printed values were unreasonable. The value jumped from positive to negative numbers without any logical order.
I would be very glad if someone could guide me through it.
Thanks,
Guy
Team #1574 Misgav High School - Israel
Winner of the 2007 Israeli Regional
Winner of the 2007 Motorola Quality in Design Award
Visit our website:
www.miscar1574.com
Problems with the gyro Conan Programming 7 06-02-2006 01:45
Gyro Code Problems railerobotics Programming 8 27-01-2006 10:45
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
