Go to Post the hardest task this year is the same as every other year: getting the engineers out of the crate so you can close it up and the FedEx guy can haul it away! - KenWittlief [more]
Unread 06-12-2006, 01:27
CraigHickman
Posts: n/a
pic: 114 drive module design
Unread 06-12-2006, 01:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: pic: 114 drive module design
Love the design, not diggin the weight so much. What are the dimensions on that box tubing? 1x2x.125? Also, if i is only single speed, why not use the KOP tranny?
Unread 06-12-2006, 01:33
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Can you talk more about each stage of the gearbox and their reductions? It's interesting to see how other teams decide to gear their robots for the sake of comparison, I think.
Also, why have you used such heavy rectangular tubing on each side of the wheels instead of, say, plate or channel? What's your overall weight for a module?
I've been tearing my hair out recently trying to distill a reliable, simple, easy to build 6WD module not unlike this for the past two months or so. I'm not quite there yet, but I'm getting closer, and it's interesting to see how others solve the same problem.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 06-12-2006, 21:59
CraigHickman
Posts: n/a
About the weight: The whole thing should weigh 12 pounds. The box extrusion on the side is 2x1x.125". We're planning to use this because of our positive experience with it in the past. The stuff is strong, decently light, and shouldn't need replacement. The module rolls on 4 inch custom wheels.
About the reductions, it starts with the stock 14 tooth input gear, and the reductions follow: 14:60;19:60, directly to the center wheel. This gives us a low speed of 7 fps. We're debating adding a ball lock shifter into the tranny, which shouldn't add too much weight or space. However, we'd like to see the game design before we decide if a 2 speed is neccesary.
pic: 114 gearbox design CraigHickman Extra Discussion 4 05-12-2006 19:53
pic: 114 2 speed Coaxial Crab Drive CraigHickman Extra Discussion 14 27-07-2006 10:08
pic: Possible Team 114 Drive Component James114 Extra Discussion 14 15-01-2005 12:27
pic: Team 710 Drive module CD47-Bot Robot Showcase 20 04-03-2004 01:21
pic: Dual-Speed Drive Module CD47-Bot Extra Discussion 3 07-11-2003 13:45
