Go to Post TL, DR: You may be skilled at karate on your own, but imagine how much better you'll be with Mr. Miyagi mentoring you. - artdutra04 [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 09-12-2006, 19:26
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
interference between wires and connectors
As seen in the attached screenshots, when I create wires, the end of the wire intersects the plane of the pin (because the center of the wire's end face is coincident with the pin, and the wire is not perpendicular to the pin's plane). I can add points to the wire directly above the pin to make the wire's end face closer to being parallel with the pin's plane. Because Inventor automatically shapes the wire so that the curves are smooth along its entire length, I can't get the end of the wire perfectly straight, and it always interferes with the blue connector part even if I add four or five points directly above the pin.
Is there a way to adjust the wire and get rid of the interference? Or do users generally ignore the interference in that situation?
ID:	4748  Click image for larger version
ID:	4749  Click image for larger version
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Lines and wires Andrew Blair 3D Animation and Competition 1 24-05-2005 21:49
update 8 clarification, drill motor and blue wires pryoplasm Rules/Strategy 23 13-02-2004 07:26
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Sprockets and Crimp connectors archiver 2000 1 24-06-2002 00:26
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
