Go to Post Our robot weighed 168lbs..... bring it on Trimspa!!! - slickguy2007 [more]
Unread 10-12-2006, 20:48
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Programing code
Hey i went to ifirobotics and tried to find the original code... cant seem to find it for 2006.... i basically need the code for the camera... for some reason i keep getting an error w/ stdio.h file .... i think it may be my complier but still not sure...
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 10-12-2006, 20:57
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Programing code
Go to Project>Build Options>Project
Include Path - "C:\mcc18\h"
Unread 10-12-2006, 22:40
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Re: Programing code
If you still need the camera code, it's here: http://www.kevin.org/frc/frc_camera.zip (see http://www.kevin.org/frc for other available code)
Andrew Neilson - Team 772 Alumnus
University of Waterloo Computer Science, Class of 2010
Unread 11-12-2006, 07:01
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Programing code
Th default code will be on IFI's site, but for the camera and other code you need to look for Kevin Watson's code. You can find his code at http://kevin.org/frc
Unread 11-12-2006, 19:46
AKA: !!Mitch!!
FRC #1392
Re: Programing code
Hm... i do have the project set to mcc18.... still getting that error... now that code from http://kevin.org/frc "the bells and whistles"....i have to include every piece of data (user_routines.c) into my own code? if yes just let me noe so i can start... i also see that there is a .mcp file in here... do i need to include that as well in the folder that al my code is in??
Unread 11-12-2006, 19:57
Team 2021 Captain
AKA: Chris Davidson
Re: Programing code
Read the readme that Kevin included with his code. It should tell you how to use his code in yours. If I recall all you have to do is make sure you have tracking.c, tracking.h, camera.c, and camera.h. Then make sure you #include the header files in your user_routine and then make sure you call all the camera initilization and tracking methods.
Unread 11-12-2006, 20:00
AKA: !!Mitch!!
FRC #1392
Re: Programing code
ok im somewhat majorly confused..... should i include all of the files found in the zipped file?? or should i only include tracking.c/.h and camera.c/.h? ... really confused im reading the 'read_me' and its telling me to delete this and add this..
Unread 11-12-2006, 20:03
AKA: !!Mitch!!
FRC #1392
Re: Programing code
I have found my problems
www.InnovationFirst.com
10/10/2005
- Added a checksum to the breaker panel packet
- now using <stdio.h>, compiler needs -nw=2066 to suppress warnings (under project->build options->project->MPLAB C18->Use Alternate Settings)
- Note: when using a 'printf' use a '\r' rather than a '\n' with the C18 compiler (v2.4 or later)
This is what has being failing on me
Unread 11-12-2006, 20:39
AKA: !!Mitch!!
FRC #1392
Re: Programing code
GUYS .. ima cry.. i do not have the 2.4v of C18... i have 2.2v but not 2.4:'( so this is probally the reason why i am getting the error....
Unread 12-12-2006, 06:59
Team 2021 Captain
AKA: Chris Davidson
Re: Programing code
If I recall, v2.2 will not work. Only v2.4 will work.
Programing a joystick Justin_302 Programming 2 21-03-2005 22:45
Programing great_one411 General Forum 2 01-02-2003 17:27
Programing of controller DLyons Programming 0 29-11-2002 20:50
Programing help... archiver 2000 9 23-06-2002 22:46
Programing pfortunejr Programming 1 08-01-2002 13:18
