Go to Post FIRST is like riding a bike. At first it may seem hard and confusing, but after a few tries you get the hang of it and its smooth sailing from then on out. - Tom Bottiglieri [more]
  #16   Spotlight this post!
Unread 31-12-2006, 02:47
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: pic: DeWalt Gearbox with two CIMs
Originally Posted by MAteo9944 View Post
Another thing that you hinted at was that if you have 4 transmissions, if some of your wheels lose grip or leave the ground then you suddenly have less torque available. (If your wheels are leaving the ground during a pushing match you have other problems.)
True but I was thinking more like climbing a ramp, once your weight leaves the front wheels the weight transfers to your back wheels. If you are running a gearbox with all wheels connected your effective force is the same because your normal force and traction is constant. If you run 1 motor to each wheel (not connected) then your effective force is much less due to the loss of normal force over your front wheels. depending on the situation it could be as much as half the total power of the system.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
  #17   Spotlight this post!
Unread 02-01-2007, 01:11
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
Team Role: Driver
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Originally Posted by newton418 View Post
To specify my question, why not get the extra torque after running each CIM through their own DeWalt transmissions? Though I have to say, if it only weights 2.5 lbs without the motors, that would be a good reason. If you build it make sure to post pictures and results!
Originally Posted by Greg Needel View Post
Running each cim into it's own transmission would not give you extra torque. In most if not all cases the total torque is the same. Since each motor has a maximum amount of power it can generate at 12 volts within the given amperage requirements all you would be doing by making separate gearboxes is spreading out the load. In this situation the only reason I would consider doing that is if I was concerned with the torque of 2 cims breaking the deWalt transmission (yes I am thinking that).
From my experience in drive train design I will always advise that people go with a central gearbox and power transmitted through chain or another means. This is due to your overall friction force (another discussion) but basically if you spread out the load to all of your wheels each wheel can take the total torque produced in the situation where another set is off the ground (assuming the mass is over the wheels touching the ground) that is where the normal force/ weight of the robot plays in (yet another discussion) either way keeping your motors together will save you weight in the long run and give you the nice ability to put the torque everywhere you want it to be in the correct situations.
What I meant by "the extra torque" is the extra torque you are getting from the second motor. Basically, you have two different scenarios:
(1) You have a transmission with a given ratio, and you have two identical motors inputting power (as in your design), then you get a specific max output torque from the transmission. This can then be connected to a drive train (preferably where all wheels are connected, so you power all wheels), determining the max output torque on the wheel axels.
(2) Now consider taking the same motors and the same transmission, and having one motor input power into one transmission. If you take two of these single motor-transmission assemblies and connect the output shaft of each transmission to a drive train (where all wheels are connected), you end up with the same max output torque on the wheel axels.
So my question is, what is the advantage to the former setup (besides potentially saving weight)?
Team 418 Purple Haze
http://www.lasarobotics.org/
  #18   Spotlight this post!
Unread 02-01-2007, 05:34
well there are a few, but by no means would they outrank a centralized gearbox in my book.
weight distribution - with each motor (cim) weighing about 5 lbs you might want an even weight throughout the chassis as apposed to a centralized one.
swap ability - for some reason if a motor burns instead of taking a transmission apart disabling your drive train (with a centralized tranny) you can just quick replace the single module that is broken.
Robot layout - sometimes it may be easier to mount 1 single motor and tranny then a full gearbox. The example that comes to mind for me is a planetary set where they are really compact.
I am sure there are more....the main thing to remember is that there is no "one and only solution" and it is all about evaluating your specific situation, and making the best decisions you can. Every team has their own reason for doing things, all of which are valid.
pic: Version 2 of the 2 CIM into 1 DeWalt gearbox MAteo9944 Extra Discussion 3 21-01-2007 13:00
Using two CIMs in the Banebots Transmission Justin M. Technical Discussion 15 09-01-2007 09:41
Flexible shafts working with CIMs mechanicalbrain Motors 8 07-07-2006 23:38
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
how to wire the new two motor gearbox Vince lau Electrical 10 14-02-2005 07:30
