Go to Post I respect what you have to say and I ask that you do the same for me. - Andrew Schreiber [more]
Unread 11-12-2006, 16:35
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
EasyC for FRC: Drive and Auto Track Camera Code
Autonomous - Robot rotates to the center of the green
target.
Operator Control - Drives in arcade mode as normal
and when the trigger is pulled on the drive joystick
the robot will disable arcade drive and rotate to
center itself.
This program has victor scaling in the drive function.
This makes the victors act in a more linear fashon.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Cmucam + track color + auto servo mode kheops1982 Programming 5 09-04-2006 13:32
Update for EasyC for FRC Available Kingofl337 Programming 0 07-03-2006 14:42
FRC Camera code in YCrCb Mode? Terry Sherman Programming 9 25-01-2006 16:43
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
