Go to Post Holy cow! Five years in FIRST and it only gets better! Skyway has supplied wheels to FIRST for ten years. Ten years ago Dean called Ken for wheels. Ken said yes. Man, we love helping you guys and gals get good wheels. ;) Bart at Skywaywheels.com - SkywayWheels [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 17-12-2006, 15:31
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
Problem getting started with USB 6009
I have installed everything per the instructions, and can talk to the USB-6009 using the Measurement & Automation Explorer. However, when I try to use the Instrument I/O Assistant in LabVIEW, I get an error dialog telling me that Measureent & Automation Explorer or the Instrument I/O Assistant is not installed correctly.
I looked again at the installation program and didn't see anything missing. I looked for related options in the LabVIEW settings and didn't see anything.
Has anyone else had this problem? Any ideas to fix it?
Thanks,
Jim Greenhaw
Unread 18-12-2006, 09:15
AngelaM AngelaM is offline
AngelaM is an unknown quantity at this point
Re: Problem getting started with USB 6009
Hello Jim,
First, you probably want to be using the DAQ Assistant rather than the Instrument I/O Assistant to communicate with your USB-6009. The Instrument I/O Assistant is designed to work with GPIB/Serial and most other devices with which you would use NI-VISA to communicate. The DAQ Assistant will help you get started in communicating with NI-DAQmx devices, of which the USB-6009 is.
Ultimately, if you do desire to use the Instrument I/O Assistant to communicate with other devices, then I recommend that you uninstall and re-install the Instrument I/O Assistant from the Device Driver CD. It is possible there was a corruption on the initial installation.
I hope this helps. Please post again if this resolves your questions or if this resolves the behavior for you.
Regards,
Angela
National Instruments- Applications Engineer
Important note about USB-6009 input voltage limitations jerry w National Instruments LabVIEW and Data Acquisition 7 11-01-2006 13:09
Ideas for using the NI USB-6009 DAQ device Andrew Schuetze National Instruments LabVIEW and Data Acquisition 0 05-01-2006 22:55
Getting Started with Scripting LBK Rules Programming 2 15-01-2005 01:28
Getting Started Cheese Head Programming 4 09-10-2002 22:24
