Go to Post Well, are comedy and sarcasm COTS items? - Karibou [more]
  #16   Spotlight this post!
Unread 18-12-2006, 20:26
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: Check Out Our New Custom Frame!
Even though you may not want to use a bumper/outside rail. I would extremely recommend it. My team uses ifi tract. wheels and without proper protection they are easily bent/broken, last thing you want is a smashed wheel out on the field. Besides that i like the concept. Though adding an outside rail would also provide a place to mount the other end of the axle, thus making it stronger and lessing the need for such big bearing blocks.
  #17   Spotlight this post!
Unread 19-12-2006, 01:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
I can't speak for the new IFI traction wheels, but if you were to run last year's version outside the frame like that, they'd last maybe 3-4 matches. You definitely want to protect them somehow.
As to snaprings, you can use them to space your sprockets and such. Make sure you leave yourself some wiggle room between the groove and the sprocket, or else the snapring will not properly seat itself. In the past we've just machined nylon/aluminum tube to the proper length and slid it over the shaft.
2001-2004: Team 100
2006-Present: Team 254
  #18   Spotlight this post!
Unread 19-12-2006, 03:28
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Its a good start but... I think you would be happier with a couple more cross frames to help keep things straight. Just my 2 cents worth....
  #19   Spotlight this post!
Unread 19-12-2006, 16:46
Viper37 Viper37 is offline
AKA: Matt Howard
Viper37 will become famous soon enoughViper37 will become famous soon enough
Send a message via AIM to Viper37
Originally Posted by EricH View Post
968 had the same problem at LA. Their only loss was when a team somehow got on top of their back frame and slowed them down, to say the least. They later added a bumper, IIRC.
I witnessed this, and it was particularly nasty. Im not claiming to know the workings of their robot, however simply put, if they shortened the width of the chasis by about 2 inches, they would have room to put stock across the axles as a sort of guard.
But after seeing how succesful that chassis was, it is only a small detail.
To address the poster, you have a good chasis on your hands. However have you considered some sort of shifting tranny? If you use them, they can give you a big advantage as far as driving goes.
  #20   Spotlight this post!
Unread 19-12-2006, 19:08
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Why shorten the width? You can get stock up to at least 10' and cut it to length.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #21   Spotlight this post!
Unread 19-12-2006, 19:18
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
One of the big advantages to having exposed wheels (such as also in the design central to this thread) is the ability to quickly replace your wheels. This is especially true on live axles (as also in this frame design). Reportedly 968 could switch an individual wheel in around 1 minute (or less) with their exposed, cantilevered, live axle design last year. Whether some sort of guard or bumper mount that is quickly and easily removable (or doesn't inhibit replacing wheels) can be added is a challenge left up to the individual team.
Being correct doesn't mean you don't have to explain yourself.
  #22   Spotlight this post!
Unread 19-12-2006, 19:40
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
How often do teams typically change wheels throughout a season? I've never had occasion to replace a wheel, but my teams often don't use the popular traction materials that wear down with time.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
  #23   Spotlight this post!
Unread 19-12-2006, 19:50
Cory's Avatar
AKA: Cory McBride
Approximately 2-3 times per competition for us.
We generally leave the tread on the bot that we tested with before ship, change it on Thursday night, change it on Friday night, and before the finals.
2001-2004: Team 100
  #24   Spotlight this post!
Unread 19-12-2006, 19:56
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
We used SBR Roughtop on a 3/4" wide wheel and it held up fine throughout VCU on a primarily defensive 'bot, very little wear although it did leave black lines on the carpet when we got into tough pushing matches. (Or reversed direction quickly) However, I understand the Wedgetop 968 used wears a little quicker, and their wheel width might be smaller, and I know their wheels were smaller diameter, so the wear couldn't be spread out as much.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
  #25   Spotlight this post!
Unread 19-12-2006, 20:02
AKA: Matt Howard
Like I said, I dont know their robot. Im just assuming it was already at max witdh.
  #26   Spotlight this post!
Unread 19-12-2006, 20:03
AKA: Matt Howard
I can think of a way off the top of my head to make a guard with 2 nuts holding it on.
Remove one, and swing it out of the way.
  #27   Spotlight this post!
Unread 19-12-2006, 20:05
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
With a system like 968's they could replace them whenever they wanted. Before the 2nd match of the Finals on Einstein, they apparently replaced one so they could drive slightly better.
  #28   Spotlight this post!
Unread 20-12-2006, 04:43
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Just to clarify, we could easily replace all 6 wheels in under a minute and I do believe we did so before that last match. By new wheels, I mean wheels with new tread. As Cory mentioned, both teams had two sets of wheels so that at any given time we could be replacing tread while the robot was still on the field.
The new tread helped us drive straighter which was very helpful during autonomous mode. We had a gyro to keep us going straight and encoders to tell us when to stop, but new tread always seemed to add consistency and lessen the error/drift.
In regards to the OP, I agree with most everyone that you should add some sort of protection for the wheels. It is something we will be doing this year for sure, one way or another.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Check out our cannon bot! Salik Syed Robot Showcase 28 14-01-2006 15:42
New old server - Check it out sanddrag Website Design/Showcase 22 07-03-2005 19:51
Check out our new site(prepare to be wowed) D. Gregory Website Design/Showcase 32 02-03-2003 21:12
Our website uses php-nuke. check it out! xxlshortys Website Design/Showcase 1 21-01-2003 19:43
