Go to Post I even have a t-shirt that says "Actually, I -am- a rocket scientist" :) - dlavery [more]
  #31   Spotlight this post!
Unread 31-05-2007, 00:56
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Steering wheel
Originally Posted by PhatMike View Post
For the most part it is, but from the teams I've talked to that run wheels (including ours), there are some "features" added to make driving easier (turning harder at certain positions of the wheel, jog L/R, shifting ease, etc). Main advantage of the wheel, you have a much larger range of motion to adjust your control.
This is a summer project I've wanted to do for awhile, but have never got around to doing it - using a mini EDU controller and the r/c car controller to try and drive the robot. Sadly, I don't have the programming background to set the EDU up to do it. It would be really cool to be able to eliminate the full sized RC and OI for doing demonstrations and stuff where the full control system isn't needed.
If you need to just use the drive base all you need is a vex kit with the default code on it. just hook it up with a Y-cable or so that you control one side with 1 PWM channel. I have hook the VEX stuff up to victors and it works perfectly, there is no reason why it wouldn't. If you need more help PM me.
-John
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Steering wheel problems jgannon Programming 4 16-01-2005 14:25
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
