Go to Post It will really be different for us (ESPECIALLY since our robot drives consistently this year). - Karibou [more]
Unread 20-12-2006, 07:27
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Printf has just entirely failed to do anything
I started with the default camera code from Kevin Watson a few weeks ago, and I have been making my modifications happily--that is, until yesterday. First, I added two of my own files, which did all the camera calls, consolidating them into a single Camera Update function. Then, I pulled the camera update function calls out of user_routines.c and put my camera update function call into Process local IO. I had something like this working last week, but it refuses to send any bytes out the serial port now.
Things I have tried:
-tested my serial link. It is good-I can send programs down + read them back with device reader. I also see IFI> when I reset the bot
-tested with another RC. Same problem.
-unplugged camera TTL converter. Same problem
-Added printfs everywhere in my code. None of them work unless I comment out the #include for serial_ports.h (this breaks the camera functionality of course) And none of the printfs produce any output
-Replaced all the files that should never have been modified (serial_ports.c/.h, terminal.c/.h, camera.c/.h are the ones I overwrote with the ones out of Kevin's code). No effect.
I'm bashing my head on the wall right now.....please help!
JBot
PS. I will post the code tonight if you need it. I am using a school machine right now and don't have access to my code right now.
Aren't signatures a bit outdated?
Unread 20-12-2006, 09:38
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Printf has just entirely failed to do anything
Which printf are you using?
The C18 library version that requires you to add "#include <stdio.h>" everywhere printf is called,
or one of the older printf_lib.c/h versions?
Unread 20-12-2006, 12:35
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
I am using the stdio.h version where it won't compile unless I #include <stdio.h>.
It "Code error"ed out when I commented out the includes for Kevin Watson's serial port code. It worked then for about 5 seconds but it gave me a red light of death afterwards, presumably because I was bombarding it with tons of printfs.
JBot
Unread 20-12-2006, 20:57
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
I really hate to do this, but since it is slowly creeping down the portal and I really need an answer...BUMP!
I am thinking about re-writing from scratch, but that would be ugly, so please, please tell me what I might be doing wrong...
JBot
Unread 20-12-2006, 22:23
Just Itinerant
Sorry, we've been racing robots all night. They're having a pushing contest now.
Probably need to attach or email your whole project to look at.
It's hard to guess what serial port resource conflict you might have. There are too many answers.
Unread 20-12-2006, 23:45
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
Definitely zip up the project, there are a number of people out here on "the internets" who will take a look and give you a hand. Not being able to debug over the serial port leaves you with few options. The "Red Light of Doom" is typically caused by the same things that would cause a Windows-type program to either crash, or it went into an infinite/extremely long loop somewhere. The infinite/long loop would be the first thing I'd carefully check for in your code, it's easier to do than you'd think.
If you are indeed the lone programmer for your team (poor guy ) you might want to force some code versioning on yourself. Things like CVS or SVN (check out wikipedia or google it yourself) CAN AND WILL SAVE YOUR BACON! It'll allow you to easily step back in time before you screwed something up, and will also provide an easier time of multiple people working on the project at once. This way you can try training an interested freshman without fear of him making changes you can't get rid of when your team leader asks you "is autonomous mode done yet?" It takes some work to understand, but I promise (and every other user of some code versioning system will promise) it will be worth the effort.
--Eric
Unread 21-12-2006, 14:11
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
I had the same sort of occurrence myself this week as I was trying to program one of the 2005 units.
Since you haven't mentioned which controller you're using this may not work.
If you have a 2005 CPU it's likely using a 8520 pic, which needs the following environment changes in mplab:
From the Configure >> Select Device... menu choose "PIC18F8520"
as the pic type
In your project use the "FRC_library.lib" for the 8520
(mine is named FRC_library_8520.lib) -To keep my sanity I
renamed it in the same
fashion as last years revised
libraries and linkers were.
Also In your project use the "18F8520.lkr" for the 8520
NOW the last ingredient for success in restoring printf's (in my case anyway)
Load the FRC_MASTER_V12.BIN and reload your first compiled code
(before all of your changes)
If you're using a pre 2006 CPU it's probably not been loaded with a FRC_MASTER_V12.BIN but an older version.
I'm just guessing (since it's now gone) but ours was probably using the V11 master code as distributed in April 2005.
Once the master code was updated my printf's worked fine (no more IFI> terminal freeze ups)
Unread 21-12-2006, 22:46
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
OK, the code that is causing me problems is posted:
http://jbotalan.frih.net/07_code.zip
No printfs work anywhere.
I'm re-writing from the default user code. It will make for cleaner code. I would be interested in finding out why the heck this broke.
I'm going to try CVS.
JBot
Unread 22-12-2006, 17:14
esquared's Avatar
AKA: Angry Eric
Team Role: Mascot
JBot
Could you add the following to timer_handler.c in the InitializeTimer() function?
Code:
PIE1bits.TMR1IE = 0;
Since you don't have an interrupt handler for that timer, but you start it, it is wise to make sure it's set to not create an interrupt. It might start out that way by default, but this is much safer. An interrupt that is generated but not handled can do very bizarre things.
If i understand your original post correctly, it stopped working when you moved the function calls into your abstraction files?
I noticed you did not call "Initialize_Camera()" in your abstraction file (or anywhere in your project). Try adding that to user_routines.c in the User_Initialization() function.
Let me know if any of these work.
-Eric
Unread 22-12-2006, 17:26
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
I'll be sure to let you know if these work. I won't be able to check until we get back (on the 4th I think). It's nice to know someone cares enough to pull down someone else's code to look at it. I wouldn't have been as generous before FIRST...
Thanks,
JBot
EDIT: I was under the impression that Camera_Handler() in camera.c was supposed to be calling Initialize_Camera(), and it is as far as I know. I can call it manually, but depending on the flags set in camera.c, it does get called if camera comms aren't working. Correct me if I'm wrong...
Unread 22-12-2006, 20:48
AKA: Bruce Johnston
Matt,
Sorry for leaving you confused.
The last step for success (in my eliminating the IFI> prompt freeze up while adding in printf's for my chosen variables) WAS the loading of the MASTER_V12.BIN from the 2006 default code.
You are absolutely correct when you mention that there is no explicit documentation of whether it's appropriate to try this.
But where is your sense of adventure.
The fact that IFI was doing FRC controller processor upgrades from ver 8520PICS to 8722PICS,
and Kevin Watson was releasing all kinds of code with instructions on how to load user programs written as enhancements for the 2006 base code onto 2005 processors.
Surely, if it were fatal to the processor somebody would have noticed by now that loading the MASTER_V12.BIN shouldnt be done on a 2005 controller.
Anyway it works, my 2005 controller is happily running MASTER_V12.BIN and both the FRC Default code and OUR 1114-1503-1680 Common base code that were teaching our programmers with.
Perhaps I should have actually read the IFI site for instructions on how to confirm which Master code we were running before I scrapped it, but I did save the bin file for posterity using device reader.
The only guessing going on was if it was v 10 or v11 not whether or not I fixed the freeze up at the IFI> stage.
Bruce
PS Jacob, I looked at your environment (8722PIC, lib & lkr) and you don't have the same printf freeze issue I had.
Unread 23-12-2006, 02:15
esquared's Avatar
AKA: Angry Eric
Team Role: Mascot
I missed that as well in camera.c so good call.
Aside from your efforts to start from the default code, I can send you a basic environment that has a working camera without too much of our robot-specific code in it just so you can verify its not the source you're building from.
Another possibility-what version of the IFI loader are you using? If you use the old version with code sizes> 32k (or whatever the max was for 2005's RC), you can get wicked crazy problems. That might explain why things stopped working as you added more functions/files.
-Eric
Unread 23-12-2006, 21:17
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
JBotAlan,
I think your problem is both obvious and simple to fix, luckily. Rearranging the Camera_Handler function etc, had nothing to do with it. Had you left the original code intact, you still would have broken the program by moving Camera_Handler() (or CAL_Update() in your program) from user_routines.c to Process_Data_From_Local_IO(). Move Camera_Handler() back where it belongs and everything will work wonderfully again.
Here's my reasoning. Process_Data_From_Local_IO(), as you know, runs stupidly fast, as it runs every loop in the user PIC. As opposed to every 26.2ms for Process_Data_From_Master_uP(). Camera_Handler() is a very complicated little function, and does tons of fun stuff like disabling serial interrupts briefly and using the inherent timing of the slow loop to get the timing of its initialization correct. Basically, with Camera_Handler() in your Process_Data_From_Local_IO(), things are happening waaay too fast and piling up and generally causing the horrible broken execution and code error lights that you're seeing.
To put it even more briefly, in the camera_readme.txt, Kevin Watson says you should call Camera_Handler() from Process_Data_From_Master_uP(). You really ought to listen to him unless you've initmately acquainted yourself with the operation of said function.
Unread 21-12-2006, 23:16
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
I'm not sure this is sound advice, I looked on IFIs website, and the latest update I see for a 2005 controller is v11. The v12 update is included with the 2006 controller code. This to me implies the update is built for the 2006 controller, and I'm not sure if it shares a master processor with the 2005. If it does share a master processor, it should work fine, but if they've changed them, such an update could make the RC...not work.
Does anyone know if the 2005 and 2006 controllers share a master processor model? Also did you actually do the Master version update on your 2005 controller? It's a little hard to understand as you speculate the controller in question was running v11.
Can someone clarify please?
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
  #15   Spotlight this post!
Unread 22-12-2006, 11:52
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Thanks so much for suggesting CVS/SVN! I now have SVN set up on my machine, and I like the looks of it. It's really cool to look at the diff of two versions of one file. I can see how this would be great at robotics.
Oh, I like being the lone programmer! Nobody to fight with over how the code will work! I'm trying to train a freshman, but otherwise I'm it.
Thanks again. You learn something new every day. If only I learned something this cool every day...
JBot
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
pic: Failed attempt at simulation CD47-Bot Extra Discussion 5 17-06-2004 11:03
printf isn't printf-ing. Help! Meandmyself Programming 14 15-02-2004 16:27
And now for something entirely different..... archiver 1999 1 23-06-2002 22:46
