ive seen people using dewalt drills on their bot (motor&gearbox, what kind can you use? how many can you use? do they work better than the cims??
Re: DeWalt motors
are you sure the DeWalt motor was being used? we used the DeWalt gearboxes on the CIMs
Re: DeWalt motors
The DeWalt transmissions work very well on robots. However, the motors are NOT allowed in FIRST robotics. If you search CDMedia, there is a paper specifically on modifying a DeWalt to make a 3-speed transmission.
Re: DeWalt motors
You should also search forum posts about using the DeWalt trannies. The original paper is a bit outdated, and some of dimensions in the drawings could probably be updated a bit. Also, the guy that's supposedly making the parts as a kit isn't really doing so anymore as of 2005, as there wasn't a lot of demand.
Re: DeWalt motors
the reason i am asking is because that team from Canada that won the nationals used what looked like the dewalt MOTOR, the motor was in yellow dewalt plastics, with the gearbox attached for the shooter's flywheels
Re: DeWalt motors
![]() http://www.chiefdelphi.com/media/photos/23405 The only FRC-legal motors that are allowed are the ones provided in the Kit of Parts. Since in many circumstances, the motors inside cordless drills are very close to the size of a Fisher-Price motor, it probably wouldn't be too hard to take the DeWalt motor out and pop in a FP and then replace the casing on the transmission. |
Re: DeWalt motors
Also, 1114 and its "siblings" did not win Championships; Northern Knights (296) I'm not sure about. Edit: For those not sure what a Fisher-Price looks like, see this picture:http://www.chiefdelphi.com/media/photos/19082 The FP is the small shiny one. Looks like the Bosch drill motors we had some time ago, and like the Mabuchis. I'd guess that a DeWalt motor looks very similar, hence the confusion. Last edited by EricH : 21-12-2006 at 22:35. Reason: Added link |
Re: DeWalt motors
You can install the Fisher Price Motor and The Globe inside a Dewalt case. Team 40 used 7 Dewalt gearboxes in the 2006 competition.
4 CIMs - Drive System, Servo Shift, Mecanum Wheels 2 FP - Conveyors, 1 Globe - Ball Feeder |
Re: DeWalt motors
They almost certainly replaced the DeWalt motor with a Fischer Price motor. The FP is actually a bit smaller than the DW motor, so it's easy (and smart) to reassemble the entire plastic casing around the FP motor to provide additional protection and support.
#10
Re: DeWalt motors
| Dewalt transmissions | Gabe | Technical Discussion | 19 | 01-01-2007 01:55 |
| Bosch vs. Dewalt | David55 | Technical Discussion | 13 | 20-05-2006 09:52 |
| Legal Utilization of DeWalt Motors | GramNegative | Rules/Strategy | 3 | 06-05-2006 17:38 |
| pic: Dual FP motors through a Dewalt XRP | Andy A. | Robot Showcase | 5 | 18-02-2005 09:07 |
| Dewalt Transmissions | Joe P | Technical Discussion | 9 | 09-09-2004 21:07 |
