pic: FRC 1726 suspension
Re: pic: FRC 1726 suspension
That looks cool! How does it work? Has it helped, or is having a suspension on only 1 wheel not enough?
It works pretty good! Sticking suspension on the one back wheel gives the two front drive wheels somewhat even pressure. Before it was way out of wack, and going over uneven floors made it even worse. Now it appears that it can keep both drive wheels firmly planted at all times.
The best part is that we only had to drill one hole in the robot. ![]() |
Sometimes drilling holes is a good thing. |
If you've seen the entire bot you would know it already has enough holes. (that's what happens when you are 40 punds overeight 3 days before ship date)
| pic: vex suspension | psyco_klown | Extra Discussion | 9 | 14-11-2006 22:18 |
| pic: Rookie Team 1726 Final Robot | yodameister | Robot Showcase | 10 | 24-02-2006 01:07 |
| pic: Real Pic of Team 1726 MegaMaid Progress | yodameister | Extra Discussion | 4 | 12-02-2006 13:23 |
| pic: Team 1726 MegaMaid Motors/Chassis/electronic board | yodameister | Robot Showcase | 3 | 11-02-2006 01:21 |
| Robot Adaptive Suspension | Andrew Blair | Technical Discussion | 13 | 09-09-2005 12:02 |
