Go to Post As long as they're not destroying each other, LET THE TEAMS PLAY! - Travis Hoffman [more]
Unread 22-12-2006, 20:06
dawilliams dawilliams is offline
FRC #2028
dawilliams is infamous around these partsdawilliams is infamous around these partsdawilliams is infamous around these parts
motor stall current vs Victor ratings
We're rookies to FIRST, but experienced with BattlebotsIQ. We've seen the 05 and 06 power diagrams and have a question or two. If the motors draw 80+ amps at stall, the main breaker is only 120 amps, and the Victor 884's only do 40 amp continuous, how do FIRST teams allow for stall conditions? Four motors at stall would exceed the main breaker, and any Victor 884.
In Battlebots we would use higher rated Victor 885's, in parallel if needed, because we had motors with theoretical (if the batteries could keep up with the load) stall currents of near 300 A @ 24v.
1. Are FIRST robots allowed more than one battery?
2. Can we have more than one main breaker in parallel off the battery (if only one is allowed)?
3. Are the circuit breakers provided in the KOP auto resetting? Main breaker auto resetting?
Any other ideas along these lines?
Nervous excitment.
Thanks,
Gooooooooooo Teams!!!
Victor 884 Fan Current Fishdude404 Electrical 2 29-01-2006 20:06
Victor Input / Motor Control Jack Electrical 5 01-12-2004 02:23
Motor Question- Victor/Spike? 1166 Motors 10 16-02-2004 16:57
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
