Go to Post What should the lesson of FIRST be? Work within your resources to build the most effective machine that you can--and, at the same time, work to increase those resources. - Billfred [more]
Unread 23-12-2006, 15:22
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
pic: 1625swervecad
Unread 23-12-2006, 15:26
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: pic: 1625swervecad
Wow! It looks really nice! Great job, how are the wheels powered, what kind of motor swerves it? I can't tell from this angle, and distance.
I bet you could do a crazy control system with a (x, y, z) axis joystick!
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 23-12-2006, 17:36
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
It would appear that each module is powered by a CIM motor, and that all 4 modules are turned by a single window motor (crab style).
Being correct doesn't mean you don't have to explain yourself.
Unread 23-12-2006, 17:52
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
nice design. One thing you might want to consider is connecting the drive modules together so torque is transferred through each wheel. This will be adventitious if any of your wheels looses traction, the torque will be transfered to other wheels, keeping your power high. This is the major downfall of swerve drives, that your total power is the sum of 4 individual modules. compared to a standard drive of adding 2 modules. The change is in overall system efficiency. Although with your design it is possible to avoid this issue.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 23-12-2006, 19:59
Aren_Hill's Avatar
Build Nifty Things
each module has its own cim/dewalt 3 speed combo driving it. and the vandoor motor to rotate them all i chose this mainly because of only having to use 1 motor and the fact we have 4 2"wide wheels in contact with the ground.
if i link all the modules together i lose the ability to turn the frame itself yes i could do two and two but the drive systems been designed to handle 1 cim per 4"diameter wheel.
the dewalt gives us 3,7,12 fps speeds
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 23-12-2006, 20:19
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
No you don't, you will still be able to turn it like an ordinary skid steering drive base if programmed correctly (and the wheels in the right orientation).
Unread 23-12-2006, 20:24
Aren_Hill's Avatar
Build Nifty Things
if you mechanically link all 4 of the modules you lose the ability to turn now if you do two sets of two connected then you can turn skid steer style.
and one thing i've done is all of the modules rotation are solidly linked. so the wheels always point the same direction.
Unread 23-12-2006, 20:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Last edited by Madison : 23-12-2006 at 20:49. Reason: I think I misunderstand the confusion.
Unread 23-12-2006, 20:52
CraigHickman
Posts: n/a
We built a swerve frame, with all of the modules linked, and were still able to skid steer. Each side of the drive train is one it's drive system, and all were connected to the same steering system.
Unread 23-12-2006, 20:54
Aren_Hill's Avatar
Build Nifty Things
sorry when i said link them all together i mean that if you mechanically link the power to the wheel(all 4 cims) you then lose the ability to skid steer the bot
what i am doing is mechanically linking the rotation of the module. so i'll still have the ability to skid steer.
Unread 24-12-2006, 03:31
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
So... you were all saying the same thing then...
Link the rotation of the modules to one motor, but each module or pair of modules will have its own power so skid steer will still be an option.
