Go to Post What I am expecting is the unexpected (what that is I don't know). - mdiradoorian [more]
Unread 25-12-2006, 17:48
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
what usb -> serial adapter should i get?
hello,
i got a new laptop about a month ago and it dosent have a serial port on it. my parents told me that they would buy me a usb to serial adapter if i tell them which one to get. basically i need to know which one to get.
/forest
ps im running windows xp
Unread 25-12-2006, 18:06
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Re: what usb -> serial adapter should i get?
I'd wait to see if the RC stays the same in 2007 before purchasing an Serial/USB adapter.
Being correct doesn't mean you don't have to explain yourself.
Unread 25-12-2006, 19:20
fimmel's Avatar
AKA: Forest Immel
good idea but i would still like to program the old bots.
Unread 25-12-2006, 20:20
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
For the holiday season, I bring the gift of wisdom!
Please search before you post!
And all of these links to just some of the other threads I found on the same exact topic....
http://www.chiefdelphi.com/forums/sh...=usb+to+serial
http://www.chiefdelphi.com/forums/sh...ad.php?t=25823
http://www.chiefdelphi.com/forums/sh...ad.php?t=24606
http://www.chiefdelphi.com/forums/sh...ad.php?t=22424
I suggest the 6 Ft. (1.8m) USB-to-Serial Port Cable... Model: 26-183 that is available at all radio shacks. This is the same adapter that the VEX programming kit has, and if FVC are using it, then I think it is a big hint that it is good. Yes it is a little pricey, but it is worth the quality.
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
I bought a Keyspan USB->Serial converter, and have been very happy with it. It works for me under both Windows and Linux.
Unread 25-12-2006, 21:16
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
I've had good luck with the RadioShack one included in the VEX programming kit.
Eric Haskins KC9JVH
Unread 26-12-2006, 00:22
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
There's the Vex one, and there's also this Keyspan one I use:
http://www.keyspan.com/products/usb/usa19hs/
It's slow though, most of them will be, they're meant for PDAs, not interfacing with this kind of hardware.
Also if you're feeling adventurous you could try an electronics project and make your own based on this nifty sucker:
http://www.smileymicros.com/index.ph...position=57:57
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 26-12-2006, 00:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
some older laptops have a serial port on the docking station, and you can buy some of those docking stations dirt cheap on ebay...like the one for my 700 mhz small/light Dell L400. And this docking station is really no more bulky/heavy than some of the usb/serial adapters are! ymmv
Unread 26-12-2006, 01:09
fimmel's Avatar
AKA: Forest Immel
that would be cool......but the new alienware laptop i have dosent have a docking station that i know of.
i may try to build my own .....then again maby not..lol
/forest
Unread 26-12-2006, 03:18
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
You might look into PCMCIA serial cards. I have had nothing but problems with the multitude of usb adapters i have tried. These would provide a true serial port.
1139 Alumni
Unread 26-12-2006, 10:41
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Don't by a Belkin! I also recommed the Prolific cable. I'm going to order the Paralax one though to try it out. Anyone see a cardbus express 3/4 rs232 adapter?
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 26-12-2006, 11:23
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
Parallax is based on the FT232RL I took some important points from the data sheet ( http://www.ftdichip.com/Documents/Da...T232R_v104.pdf ):
• UART interface support for 7 or 8 data bits, 1 or 2 stop bits and odd / even / mark / space / no parity.
• Fully assisted hardware or X-On / X-Off software handshaking.
• Data transfer rates from 300 baud to 3 Megabaud (RS422 / RS485 and at TTL levels) and 300 baud to 1 Megabaud (RS232).
• 256 byte receive buffer and 128 byte transmit buffer utilising buffer smoothing technology to allow for high data throughput.
• FTDI’s royalty-free VCP and D2XX drivers eliminate the requirement for USB driver development in most cases.
• In-built support for event characters and line break condition.
• FIFO receive and transmit buffers for high data throughput.
• Adjustable receive buffer timeout.
• Synchronous and asynchronous bit bang mode interface options with RD# and WR# strobes.
• New CBUS bit bang mode option.
• Support for USB suspend and resume.
• Support for bus powered, self powered, and high-power bus powered USB configurations.
• Integrated 3.3V level converter for USB I/O .
• Integrated level converter on UART and CBUS for interfacing to 5V - 1.8V Logic.
• True 5V / 3.3V / 2.8V / 1.8V CMOS drive output and TTL input.
• 3.3V to 5.25V Single Supply Operation.
• Low operating and USB suspend current.
• Low USB bandwidth consumption.
• UHCI / OHCI / EHCI host controller compatible
• USB 2.0 Full Speed compatible.
Royalty-Free Drivers For:
• Windows 98, 98SE, ME, 2000, Server 2003, XP.
• Windows Vista / Longhorn*
• Windows XP 64-bit.*
• Windows XP Embedded.
• Windows CE.NET 4.2 & 5.0
• MAC OS 8 / 9, OS-X
• Linux 2.4 and greater
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Well, this is discussed in this thread:
http://www.chiefdelphi.com/forums/sh...rial+adapte r
(I'm a little embarrassed after reading this thread; the thread creator is none other than the programmer I worked with on T3 last year... )
I have noticed that it isn't the hardware that matters so much as the driver that comes with it. It's really a shot in the dark.
Ensure there is a good return policy on the one you're going to buy, and go for it. Try it out. Return it if it doesn't work.
I would tell you what I've got, but I am not even sure, there is no brand name or model number anywhere on either of my converters.
Good luck...
JBot
Aren't signatures a bit outdated?
Unread 25-12-2006, 18:11
RebAl's Avatar
http://www.parallax.com/detail.asp?product_id=28031
  #15   Spotlight this post!
Unread 25-12-2006, 18:19
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Originally Posted by RebAl View Post
That one might be a better bet. All the ones I've had are based on a Prolific chipset; I've gotten drivers from their website:
http://www.prolific.com.tw/eng/Download-2.asp?ID=17
It's good to see that Prolific doesn't have a monopoly.
JBot
EDIT: Some of the devices I've used with a Prolific chipset have become flaky, so you might try the Parallax first.
USB-Serial Adapter and IFILoader under Linux Venkatesh Programming 3 03-12-2006 22:52
intelitek loader/vex USB-serial adapter driver MrForbes Programming 2 07-04-2006 13:37
USB serial adapter for OSX? Validius Programming 1 05-01-2006 01:43
USB-Serial adapter Bill_Hancoc Chit-Chat 4 03-01-2006 07:18
USB to Serial adapter John Gutmann Programming 7 09-05-2005 01:34
