Go to Post "Why do it the easy way when you can do it the hard way?:rolleyes:" - EricH [more]
Unread 30-12-2006, 11:23
MAteo9944's Avatar
MAteo9944 MAteo9944 is offline
Knowledge Sponge
AKA: Matt Carroll
FRC #1379 (Gear Devils)
Team Role: Leadership
MAteo9944 will become famous soon enough
Send a message via AIM to MAteo9944
Re: pic: Shaft Drive Bearing Blocks
Originally Posted by Tom Bottiglieri View Post
I would not want to have to fix that thing...
Dropping a chain is one thing. Swapping out a whole shafting system might turn out to be another.
In the case of a failure I plan on having an extra side module pre-assembled to swap out.
Unread 31-12-2006, 11:37
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Matt,
I know that the drawing may not show the components in correct scale but with this kind of drive there are some significant forces that need to be addressed. The rotational forces on each shaft when pushing or in stall will produce a side force if you think about it. Because of those forces, larger bearings and stiffer blocks are needed relative to other types of drive. Without the extra beef, misalignment and high frictional forces will occur in the bearings and shafts. Think of the construction of a car differential and you will get an idea of the kind of strength you will need.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 31-12-2006, 15:20
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
FRC #0862 (Lightning Robotics)
Not2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond repute
There's been alot of good engineering concerns (side forces, stress on the shaft, etc...)
Here's one more.
Imagine hitting it with a sledge hammer. Can you get it working again in 5 minutes? Can you get a chain drive working again in 5 minutes?
Brian Graham
Unread 31-12-2006, 17:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
How about mounting both bearings on either side of one support, and get rid of the othe support? it would save some weight, and should give adequate strength to hold the gear in alignment.
Unread 31-12-2006, 19:29
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Great work on your drive train system! One thing to think about that I thought of... How about making a worm gear system. I think this would be more reliable than the one that you currently have, and you will have much greater control of your robot. The only thing is that you probably would want a fairly small gear on the axle that goes to the wheel.
Just my $0.02...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 31-12-2006, 20:10
MAteo9944's Avatar
Knowledge Sponge
AKA: Matt Carroll
Just my $0.02...
The problem with worm gears is in the efficiency. They are usually about 60-70% efficient as opposed to the 95% efficiency of a miter gear. Some worm gears are even as low as 20% though I have also seen 98% reported.
Unread 31-12-2006, 22:27
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Depending on the game and strategy, the resistance of worm gears to being back driven may be advantageous, or a significant disadvantage. However, I think it would take a lot of strategy advantage to make up for the loss in efficiency.
And it would make it about impossible to push the robot around without turning it on and having the controls. Since it usually has to go in the back of my truck to go to demos, etc. I would really hate that
Unread 01-01-2007, 11:22
RyanN's Avatar
RyanN
I was not sure of the efficiency of a worm gear system. I did not analyze how a worm gear system would be disadvantageous to a team and only looked at the advantages. I saw that the robot would be very responsive (Like when the driver would let go of the joysticks, it would immediately stop) and that other robots could not push my team's robot around, but then you said that it would be a "significant disadvantage," which I can see happening very easily. It would be almost impossible to push a locked robot across the field in the time frame that FIRST gives us during a match. Another disadvantage I found, and I'm not sure if you guys said or not, is that when pushing a robot, the efficiency of the system decreases as friction between the gears increases... I remember this now from my Erector Set when I was a kid. Brings back some memories... Now back to reality; now that I see the disadvantages, I would not use a worm gear system. I guess another advantage that I thought of is that this system would probably be more reliable than our traditional chain method.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
