Go to Post sometimes you just have to escape the wheel. - Tytus Gerrish [more]
Unread 02-01-2007, 15:52
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
pic: Isometric View of A 6WD module
Unread 02-01-2007, 15:54
CraigHickman
Posts: n/a
Re: pic: Isometric View of A 6WD module
I like! A couple questions...
How thick is the outside plate?
What size chain are you going to use?
How will you tension said chain?
Are you planning to use the kitbot gearbox?
Looks very nice and solid, a good robust design.
Unread 02-01-2007, 16:02
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
The plate is probably going to be .20" Thick, and we've always had luck with 25 chain on our 'bots. As for tensioning the chain, I am currently designing a two-sprocket Idler that will clamp on to the cross-pieces between the wheels.
For right now, we are planning to use the Kit boxes... a lot of the reason for that stems from the fact that we have so many spares laying around.
Also, the wheels pictured are skyway 6", but we will probably be using something different.
Unread 02-01-2007, 21:24
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Here is another Design which was drawn up by Andrew Blair. Believe it or not, it is lighter that the above one... and it looks much more evil.
Unread 02-01-2007, 21:31
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
How're you planning on cutting the plates? Milling squares is no fun at all and will keep you busy with a file for a long, long time. I've never had the occasion to cut square holes on our plasma cutter, but I'm sure it's a better alternative.
As I recall, y'all can weld things, yes? That makes arranging something like this quite a bit easier, I'd imagine.
What is the taller part between the two wheels for? I'm guessing it'll accept a transmission, but I'm not clear how it fits in.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 02-01-2007, 21:34
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
We'll probably have it CNC punched... or "Lasered" .
As for the huge outcropping, I 'm pretty sure It is just to support the kit Transmissions.
And I think we can weld, after all we've only had one person set themself on fire...
Unread 04-01-2007, 00:02
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Ok, We've revised it somewhat, combining the two together. This is designed to fit down into the kitbot frame and bolt into place. All the axles will be driven, and the sides will be made of .125" plate. We are torn between welding the standoffs to the plate or having them bolt in place, but we'll see what happens.
Unread 04-01-2007, 16:49
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Um, maybe a stupid question here, but if you're using the kitbot frame to place this into, why are you even bothering with the side plates. Just use the kitbot rails to mount everything to. Am I missing something obvious that this design provides that the kitbot doesn't?
Overall, I'm confused about the whole design, but maybe that comes from my point above... The standoffs, which look quite bulky and overly complicated, look like they'll interfere with all your chain runs.
If you're able to laser cut the side panels, make them straight edged instead of rounded. This will allow you to put a small 1/4" bend into the top and bottom edges, providing a MUCH stiffer side panel. (Think, kit gearbox top support plate...) That way, you can remove most of those standoffs and just put a couple, well-placed hex standoffs at the corners and in the middle.
Are those custom wheels, or just custom hubs for the skyways? I guess you're trying to make live axles, but I'm not exactly sure why... Could you please add some more detail to the description of this setup.
Sorry if this seems like I'm harping on the design. I just don't understand why all the custom/elaborate machining is required.
Thanks,
BEN
Unread 04-01-2007, 17:19
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Ben,
We have had our share of drive train issues in the past couple years, and intend to resolve them, without a huge amount of weight increase for reliability. The modules will provide the ability to quick-swap modules, damaged, inoperable or otherwise, in a very, very short amount of time. They also provide the option of live-axles, which will alleviate some of our machining headaches (Bolt circles and the like). For us, broaching is easier than fighting with many custom bolt circles. We use an elevator wheel, and in order to interface it with our drivetrain, we need a custom hub and sprockets. Live axle allows us to standardize components.
As far as the frame goes- the kitbot frame is simply an option. Ideally, we'll weld our own out of box tubing, but should the need arise, we are capable of using the provided frame. The standoffs are just another design beef-up, and we intended to use fairly large sprockets (1.5") to begin with- so the chain run will not be affected.
As far as the lip idea goes, I like it. However, when we give the drawings to our sponsor, it's often a courtesy, (and a time factor) to simply have them free up one machine for a few minutes to cut a part- reducing the number of operations they must complete. I do see the strength benefit possible however, and we definitely will look into it.
As a rule in the design, we were looking for ease of removal, robustness (very important), and perhaps most of all, aesthetics. But thanks for the constructive criticism, and keep it coming! It helps to have another view to make it better. All the CAD has been done by Cody thus far though... Hopefully we get done soon for his sake!
EDIT- Also, the standoffs won't be nearly as bulky in the final product- we're using an old version of the bolt plate, and twice the number.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
pic: 6WD Module Madison Technical Discussion 20 12-01-2007 10:09
pic: Completed Mecanum Module Madison Technical Discussion 9 12-11-2006 19:39
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
Displaying cosmetic threads in an isometric view on a drawing? Elgin Clock SolidWorks 10 07-05-2006 15:02
pic: 217 Gen 2 Crab Module Section view CD47-Bot Robot Showcase 2 28-04-2003 18:26
