Go to Post FIRST is not really located in Manchester NH but with each student and mentor involved - UCGL_Guy [more]
Unread 02-01-2007, 20:15
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
compiler error
hi
ive been trying to compile the camera code and keep getting this error
Executing: "C:\MCC18\bin\mplink.exe" /l"C:\mcc18\lib" "C:\frc_camera\18f8722.lkr" "C:\frc_camera\camera.o" "C:\frc_camera\camera_menu.o" "C:\frc_camera\eeprom.o" "C:\frc_camera\ifi_startup.o" "C:\frc_camera\ifi_utilities.o" "C:\frc_camera\main.o" "C:\frc_camera\serial_ports.o" "C:\frc_camera\terminal.o" "C:\frc_camera\tracking.o" "C:\frc_camera\tracking_menu.o" "C:\frc_camera\user_routines.o" "C:\frc_camera\user_routines_fast.o" "C:\frc_camera\FRC_library.lib" /o"camera.cof" /M"camera.map"
MPLINK 4.02, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - Coff file format for 'ifi_library.o' is out of date.
Error - Could not build member 'ifi_library.o' in library file 'C:\frc_camera\FRC_library.lib'.
Errors : 2
has anyone gotten this error before, how do i fix it
thanks
malhon
Unread 02-01-2007, 20:18
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: compiler error
Are you sure you're using MCC18 v2.40?
Unread 02-01-2007, 20:19
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: compiler error
I have not seen this particular error, however, I have a few suggestions:
-Are you running the versions of MPLAB and C18 that came in the 2006 KOP? If not, there's your problem--newer versions of the C18 compiler will not work to compile our robot code.
-Have you tried a clean build? Does MPLAB say "Deleting file.... .o" a few times before it compiles?
-Which code are you trying to compile?
Good luck
JBot
EDIT: HAH! dhoizner beat me! Oh well, I'll leave this here anyhow
Aren't signatures a bit outdated?
Unread 03-01-2007, 08:16
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: compiler error
The IFI libraries were compiled with the old version (2.4). The new linker cannot link those libraries. You need to go back to version 2.4 of the compiler.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 04-01-2007, 16:55
AKA: Malhon Godwin
Re: compiler error
Thanks! I was running the new 3.02 version, so I installed the old version and it works like a dream! I had to do the same thing with IFI Loader too to get it to download to the robot.
Thanks
Malhon
Unread 05-02-2007, 15:21
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
Re: compiler error
does anyone know where I can get the 2.4 version of the compiler
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
WEIRD compiler error Rickertsen2 Programming 7 05-02-2005 14:09
Confusing Compiler Error UrsaMNet Programming 2 28-10-2004 14:32
