solenoid valves?
Does anyone know how to wire and use the solenoid valves from the 2006 KOP?
Re: solenoid valves?
Here is the website with the Festo instructions. 2005 and 2006 Festos are the same.
http://www.festo.com/INetDomino/us/e...8b004fc634.htm Pete |
The Rexroth-Bosch celenoids are similar to the FESTOs in wiring but instead of quick connects for the tubing you put a nut on the tube and then screw the nut onto the fitting on the celenoid itself.
GO REXROTH-BOSCH!!! |
| Q&A Discuss: Cylinders + Solenoid valves | CD47-Bot | Extra Discussion | 1 | 05-02-2003 17:21 |
| Cylinders + Solenoid valves | Greg | General Forum | 2 | 28-01-2003 09:29 |
| Does anyone have extra solenoid valves????? | Elgin Clock | Pneumatics | 5 | 18-02-2002 12:43 |
| 5 cylinders, 4 electronic valves | Wayne Doenges | Technical Discussion | 5 | 27-01-2002 16:14 |
| Leak of FIRST Valves | Andy Baker | Rumor Mill | 0 | 12-10-2001 23:20 |
