Re: Robot ideas
Yes, you would be a valuable alliance partner. But keep in mind that your alliance partners may have problems, if they fall over or have a drive malfunction they won't be able to make it to the end zone and you won't be able to lift them, and won't get your 60 points. If you can score some rings in addition to lifting, you'll be even more valuable.
Re: Robot ideas
Lifting mechanisms are going to require some very careful and good thinking if you want to ensure you can lift ANY robot. |
Re: Robot ideas
Re: Robot ideas
any way a robot can have a high torque elevator, ground level. Also it can have an arm folded within this space.
The robot can play as a offensive tube stacker until the last 15 seconds. Then it gets a robot to drive on its elevator, and slowly lifts the elevator to 12"s. |
Re: Robot ideas
i was talking about the bonus points with my dad yesterday, and we came up with this idea.
1. your robot is fairly flat-backed, and about as tall as the sideboards (this is assuming a forklift-style innertube manipulator near the front of back of the robot: something tall, but not very deep). 2. you have a pair of springloaded panels on the back of your bot, such that if you pulled your bot parallel with the sideboards with a couple of feet in between them, you could release them and one would flip out laterally to create a platform, supported on one side by your robot and on the other by the sideboards. 3. the second panel that i was referring to would be attached to your first panel, but in a way that it would funtion as a ramp. i know the explanation is vague and probably tough to understand since i can't stand here and pantomime everything with my hands. it's also probably deeply flawed in ways i haven't noticed, but i mean this comment as a sort of jumping-off-point, something to get people thinking. take it however, i just thought it warranted at least a mention. |
Re: Robot ideas
I'm thinking a possible hook, suctioncup, or corkscrew design for a manipulator to transport ringers. I can't seem to find pictures of other's designs like this although I am sure they are out there.
2005 team 16 and team 1543 used corkscrews 2004 team 16 did a very good suction cup design to more arount the 2x multiplier ball. |
Re: Robot ideas
Re: Robot ideas
Re: Robot ideas
But back to the topic. I've been doing some research and some thinking and I have thought up of at least 7 different ways to build ramps so there isn't going to be a problem with finding a way to do it. Also these tubes weigh only ~1 lb. You wouldn't need much of an arm to manipulate them. Plus the suction cup system they give us seems to work nicely (from what I’ve heard on these forums). I really don’t see the issue in making a robot that can both be a ramp and place tubes. The only thing I see coming into play is deciding exactly how to get everything within the size restriction for your weight class. Obviously a shorter robot is nice for weight, but it becomes harder to get to the high tubes. This year I can't wait to see all of the different robots at competition because I do believe that we will all be surprised at how different they will all be. Until then though, good luck teams! |
#10
Re: Robot ideas
Too bad we can't attach to field elements
One of our mentors suggested suction cup-ing to the plexiglass at the end of the match to get 1' off the ground ![]() 670's thinking about an elevator-type mechanism... ![]() |
#11
Re: Robot ideas
Our team had the same idea as some others on this post. we were considering making a forklift style capable of lifting ourselves and one other. do you think this idea is plausible? And another question. if our robot is a lifter style and our teammate is flipped do u think it is against the rules to flip our team bak over?
#12
Re: Robot ideas
Re: Robot ideas
Unless you can levitate. ![]() |
#14
Re: Robot ideas
yeah i just read it again and a friend told me. lol. thanx for pointing out though.
#15
Re: Robot ideas
| Fundraising Ideas | chipvalley59 | Fundraising | 6 | 08-09-2005 13:58 |
| Any ideas for an "art robot" | ninratmny | General Forum | 11 | 11-11-2004 20:25 |
| Any ideas for a robot name? | Ryan M. | Chit-Chat | 20 | 10-02-2004 23:36 |
| Ideas | SH_Animation | 3D Animation and Competition | 9 | 26-01-2004 16:53 |
| Robot Types (post your ideas here) | Rick | Rules/Strategy | 30 | 10-02-2002 12:09 |
