Go to Post One of the Minbot inspectors at LA asked me how much a switch had to weight before it stopped being a "light" switch and started being a "heavy" switch. - ChrisH [more]
  #16   Spotlight this post!
Unread 08-01-2007, 17:31
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: I have a quistion about stopping the autonomous mode...
Originally Posted by jgannon View Post
...but don't make a habit of doing it that way. Get a dongle. Build one yourself, or order Andymark's. The competition port is not fused, and some pins are connected directly to the processor in the OI. If you touch the wrong two pins together, you may damage the OI.
That, and a dongle is a good safety mechanism to have handy. We've had more than a few "runaway bots" during autonomous testing, especially when someone disconnected the shaft encoders while adjusting wiring.
Heck, I'm tempted to make a "deadman's switch" dongle for some of our tests.
  #17   Spotlight this post!
Unread 08-01-2007, 22:01
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Need I mention When Robots Attack?
  #18   Spotlight this post!
Unread 08-01-2007, 22:42
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
assume the worst. include a deadmans switch on the controller, just in case. that way, if the program works, you smile!
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
  #19   Spotlight this post!
Unread 08-01-2007, 22:59
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
I made it a general rule that loops are NOT allowed in our code. If a loop is messed up then you have big problems on your hand. Besides why have a loop inside a loop to do the same functions a state machine can do or a timer variable
  #20   Spotlight this post!
Unread 09-01-2007, 14:10
razer razer is offline
FRC #1690
Rookie Year: 2007
razer is an unknown quantity at this point
Ok but How can I test it at school?
  #21   Spotlight this post!
Unread 09-01-2007, 16:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Use a "dongle" on the competition port of the Operator Interface. You can enable/disable the robot, and you can switch between autonomous and teleoperated mode.
http://www.ifirobotics.com/docs/comp...guide-reva.pdf
  #22   Spotlight this post!
Unread 10-01-2007, 16:07
FRC #1690
Rookie Year: 2007
and where do i connect the "dongle"?
1 side to the Competition Port at the Operator Panel.
where to connect the other side?
  #23   Spotlight this post!
Unread 10-01-2007, 21:31
Software Architect
There is no other side. It plugs into the OI's competition port, period.
  #24   Spotlight this post!
Unread 11-01-2007, 00:21
FRC #1690
Rookie Year: 2007
uh? what do you mean "no other side"? how deos this "dongle" looks like?
i think i found PDFs which explains more about the competition port, and it says i have to bring an On/Off switch, and to connect pin 5, 6, and 8 (on the competetion port) to the switch.
is this what you say?
  #25   Spotlight this post!
Unread 11-01-2007, 07:52
Software Architect
One switch between pins 5 and 8 selects autonomous mode when closed, the other switch between pins 6 and 8 disables the robot when closed. The third switch on the drawing does nothing unless you're using a pre-2005 control system. http://www.ifirobotics.com/docs/comp...guide-reva.pdf tells you what you need to know.
With a DB15P connector, two SPST switches, some wire, and a box to mount the switches on, you'll be able to make a very useful tool for testing and operating your robot.
  #26   Spotlight this post!
Unread 11-01-2007, 15:43
AKA: Jamie Bliss
If you don't understand what that means, hand the drawing to your Electrical mentor and ask him/her to build it.
Or go to AndyMark.biz and buy theirs.
Autonomous mode... to the max Total Meltdown Programming 16 18-01-2006 22:19
How do I enter the Autonomous mode? CompMaster Programming 5 17-02-2005 19:12
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Anybody have a code for an autonomous mode to go to the 50 point bar???? and... chaoticprout Programming 9 06-11-2004 12:22
counting in seconds for the autonomous mode?? Pattyta Programming 22 31-03-2004 12:55
