#16
Re: Universal Robot Connector
What if instead of making a universal latch, for all teams, wouldn't it be better if the teams that planned on specifically lifting robots to make a set of their own latches? Then they could instruct teams on where to place them. With this in mind, i think each team should make sure that their robot is 1/2 - 1 lb underweight (lol, like that would ever happen), so that if they are paired up with a lifter, then it would be much easier to work within the rules.
#17
Also, there is no need for a latch. If you can make your lifting bot lift the alliance member in a smooth motion then you will not have to have a latch. the weight of the robot will be enough to hold him on you lifting surface, and if anything else the other team can thrust forward in order to keep the robot tight on your lifting plane.
#19
It was easy just after kickoff, with that crazy image from the animation in our minds, to immediately think of a latch. Some kinda ramp may end up being much more versatile, maybe one which raises to horizontal after the robot has driven onto it.
#20
Aha! But a ramp that can lift 240lbs? (2x120lb robots in theory)
#21
All the rules say is the the lowest point of the other robot must be 4+ or 12+" off the ground. |
#22
lol i had exact same idea its the simplest and yet it would work with any robot that moves without additional requirements. |
#23
I wasn't thinking of it being nearly as steep as the ramps were last year, since most robots with center wheel drive couldn't get up. One of my team members calculated that the simplest ramp to make would have about an 18° slope. Is that reasonable for most 'bots? Last edited by usbcd36 : 07-01-2007 at 22:47. Reason: forgot to include quote |
#24
Someone just say it so it's out in the thread for discussion. |
#25
[120# + 13# (battery) + 15# (bumpers)]*2 = 296# I think we will probably see more ramps than arms...can you imagine a robot trying to lift another robot and seeing it tip over? I'm positive (and hopeful) that teams would think about such a scenario beforehand, but I don't see going through all the trouble when a ramp is easier to build. |
#26
ChrisH |
| Universal Game Winning Robot/Strategy for any year | sanddrag | Chit-Chat | 6 | 06-04-2006 16:36 |
| UNIVERSAL Emulation? WHAT!?!?! | Joe Matt | Chit-Chat | 5 | 12-10-2004 12:52 |
| Universal Robot Unvaling Thread | Joe Matt | General Forum | 5 | 05-01-2003 12:09 |
| 90 degree robot modem connector | archiver | 2001 | 10 | 24-06-2002 00:03 |
| Release of Universal Terms... | archiver | 2001 | 1 | 24-06-2002 00:01 |
