Re: 2007 Kit
Comparing last year KOP drive train with this year. 2006 the drive train with the addition of 2 21 tooth sprockets, 2 28 tooth sprockets, a box chain and 4 kludged up wheel adapters gave a team a nice 4 motor 4 wheel drive base. Could be done in one night. With this year's kit we get 2 wheel drive and the opportunity to spend allot more $$$ to get 4 wheel drive out of the kit drive train. What do we do? Buy 2 more 56 MM gear heads and associated sprockets and go with four wheel independent drive or buy the 2 cim gear case add on and use 1 56 mm gear head. I have reservations about putting 2 cims into 1 56mm gear head. Maybe others will have a more analytical comment on the input handling of the banes bot gear heads. Then there is the output shaft loading issue that Banes bots warns about and the additional bearing plate they sell because of it. Then again we could just use the 2005 KOP gear boxes. They're in pristine condition and have proved to be robust.
The Andy Mark KOP wheels have much softer rubber. The Skyway wheels last year wore down allot. I'm afraid the softer compound may be a wear problem. I think we may put disposable rubbers on the wheels. Also I think the Skyway wheel profile was a positive when driving on carpet. I can see the BB gear heads being a positive for our arm drive. The encoders available from BB are a definite step forward. Over all with less then 24 hour I have to say the kit is 2 steps forward and one back. Our team is going to need some additional funds to make this work this year. Last year we got away real cheap. |
Re: 2007 Kit
I just want to verify that, as per the KoP checklist on the FIRST site, we're only supposed to have one Fisher Price motor and gearbox. We received two in our kit.
Did anyone else get two? |
Re: 2007 Kit
We got two, I was just about to post the same question.
Re: 2007 Kit
We got 2 as well.
Re: 2007 Kit
We recieved two as well.
Re: 2007 Kit
I was wondering about this as well. The checklist says 1, but both 494 & 70 got 2 Fisher-Prices. I think the checklist is wrong, considering that we've gotten two in the past and it seems every team got two.
Re: 2007 Kit
Yes, I have been wondering if FIRST thought at all about the environmental impact of suddenly making thousands of existing perfectly good batteries obsolete overnight. I suppose they are good for practice and use in previous years robots for demos and such but I still think this was possibly the most environmentally UNfriendly move FIRST has ever made. What a waste. Folks if you don't want, need, or have a good use for your old (now obsolete) batteries from previous years PLEASE consider either finding a new useful home for them or at least properly recycle them.
Re: 2007 Kit
The pessimist in me thinks that this rule was written simply to drive extra (unnecessary) business to a new FIRST supplier. The optimist in me certainly hopes this is not the case, but so far the batteries seem identical so I can't figure out why there'd be any technical reason to prohibit last year's batteries.
Re: 2007 Kit
The Battery issue seems to be recurring. FIRST rules that because the battery has a new part number, it is different then previous batteries.
Teams argue that there is not significant difference between previous batteries and the new ones, and should be allowed to use older models. FIRST responds by saying that its okay that only two batteries will be allowed, because you can charge them overnight. Teams are perplexed, and frustrated that FIRST doesn't 'get it'. The worry isn't with starting the day off with fresh batteries, but finishing it with fresh batteries. It seems like FIRSTs expectations of battery use and use in reality are very different. Refs and inspectors at regionals do 'get it' and no trouble is encountered. Why this has to come up, year after year, is beyond me. Perhaps FIRST should just specify that the kit supplied, or equivalent, battery is legal for use. It would solve a whole bunch of headache. Now that thats out of my system. I have not be able to go over the kit list in detail. Is anything noteable missing? Specificly things like motors and major electronics components. |
#10
Re: 2007 Kit
I'm hoping that they'll change it to allow equivalent batteries, though I doubt they will. |
#11
Re: 2007 Kit
Re: 2007 Kit
In 1997 (for Toroid Terror) I was the battery "supplier". The batteries that year were used in a 12V cordless Skil-Bosch drill made by another division of the company I work for. My management OK'd buying a few hundred extra units to donate to FIRST. Things were simpler then -- only about 150 kits, if I recall correctly, with two batteries per kit and about 200 spares. We also supplied a similar quantity of the battery chargers, drill motors, gearboxes, and drill housings from the same product. Just look at this awesome 2007 kit of parts! FIRST has come a long way! |
#13
Re: 2007 Kit
Re: 2007 Kit
The fact that the MK-12 batteries and the previously available Exide batteries can both turn over a motorcycle engine is interesting, but totally irrelevant. It takes about 90 seconds of research to determine that the batteries are NOT the same. Their characteristics, charge rates, and - most importantly - discharge rates are different. And those differences have significant implications for robot performance in a competition application such as FIRST. To ensure that the performance of the power system used in the competition is predictable and consistent for all teams, FIRST has to require that every team use the same make and model of battery. So next time, before anyone accuses FIRST of being in the pocket of the sponsoring corporations, they might spend a minute and a half to actually apply some of that critical analytical ability that we are supposed to be demonstrating as educated engineers, and think objectively about the rationale that might be used for the various decisions that are made regarding the competition, Kit Of Parts, and robot requirements. You might find that it is not really due to some nefarious financial plot on the part of the people that are supporting this program, but that there is actually an understandable, logical reason that is obvious once you think about it. -dave |
#15
Re: 2007 Kit
Again, I apologize to anyone I may have offended and promise not to do it again. Last edited by Kit Gerhart : 08-01-2007 at 15:21. |
| 2007 Canadian kick-off Jan-6-2007 media coverage | Mark Rozitis | FIRST In the News... | 3 | 07-01-2007 18:31 |
| 2007 Kit Transmission | Brandon Holley | Rumor Mill | 1 | 06-01-2007 01:40 |
| ***FVC Programming Kit/Bundle Kit Upgrade*** | KathieK | FIRST Tech Challenge | 0 | 04-12-2006 19:57 |
| **FIRST EMAIL**/2007 Kit of Parts Info | Mark McLeod | FIRST E-Mail Blast Archive | 15 | 09-11-2006 15:38 |
| pic: Kit Transmission Upgrade kit | Andy Baker | Extra Discussion | 17 | 29-01-2006 01:27 |
