2007 Motor Specs
This thread is for people to post specs of the 2007 motors.
New motors: the two banebots motors. spec spec spec! I'm off to work spec-ing them up, will post. |
Re: 2007 Motor Specs
Banebots RS-540 motor
Nominal v: 12v, No Load RPM: 16800, Stall Current: 42A Kt: 0.94 oz-in/A, Kv: 1400 rpm/V, Efficiency: 71% more info here Motor Specifications Performance Operating v : 4.5v - 12v Nominal v : 12v No Load RPM : 16800 No Load A : 1A Stall Torque : 39.48 oz-in 278.8 mN-m Stall Current : 42A Kt : 0.94 oz-in/A 6.6 mN-m/A Kv : 1400 rpm/V Efficiency : 71% RPM - Peak Eff : 14525 Current - Peak Eff : 6.6A Physical Weight : 5.4 oz (153g) Length - for motor : 1.97 in (50mm) Diameter : 1.41 in (35.8mm) ShaftDiameter : 0.12 in (3.2mm) Shaft Length : 0.3 in (7.6mm) Mounting Screws (2) M3 Banebots has added a link on their home page for FIRST teams, which goes straight to the parts included in the KOP. Last edited by Gary Dillard : 06-01-2007 at 17:35. |
Looking at <R27> in section 8.3.4 leads me to believe that once again we have a different fisher price motor to spec out this year, unless its the same as the one we had two years ago because it says
We are back at it again. It does not look like FIRST has published the FP motor specs this year. I have searched through all my previous posts (back to 2002) and checked all the FP motor specs I have published in the past. This year's motor is different from the 2002, 2003, 2004, 2005, and 2006 motors.
One thing is certain: the motor is made by Johnson Electric. That is good news since I should be able to get the data from JE this week. Our gear on the motor is 19 teeth, but I do not know if everyone's is the same. I will post to this thread when I get the motor data. |
Does anyone know the motor specs on the Keyang Motor?
Are we going to get power/rpm/ current curves on these RS-540 motors as we have in the past with new motors in the kit, or do we have to estimate it ourselves?
The gearmotors specs. can be found here: http://www.banebots.com/pc/MP-36XXX-540/MP-36064-540 The motor specs. without the gearbox are here: http://www.banebots.com/p/M2-RS540-120 They don't have the curves themselves, but there's at least some information available. |
Power (output) it torque times speed. Well... Watts = N-m * radians/sec. or = N-m * RPM/60*2*pi.
RPM decreases linearly from no load speed at ... no load, to zero at stall. Thus, max power is always at half the no load speed. Thus, Max power for the RS540 is ~122W. The RS 545 is 108W. This is, of course, highly approximate. But you really should be designing below Max power anyways, right? |
#11
Would it be legal to buy 2 extra 56mm Planetary Gearbox, 12:1? The same one included in the KOP?
Also, how much do these gearboxes weigh? Last edited by Arkorobotics : 09-01-2007 at 00:34. |
#13
Perfectly legal. It's COTS item offered by BaneBots and it costs less than $400. Well. Perfectly legal as long as you still stay under your $3500 limit.
EDIT: I weighed them in at around 2.5 lbs apiece last night. The only scale I had was a bit nutty, so YMMV by +/- .25 lbs. |
#14
They're about 2.5 lbs. without the motors. The motors themselves are about another 2.5 lbs. each, as I recall.
| Motor Specs??? | tenfour | General Forum | 1 | 10-01-2003 17:56 |
| motor specs? | Gary Dillard | Motors | 0 | 04-01-2003 17:54 |
| What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. | Robb Gerber | Motors | 2 | 23-01-2002 08:58 |
| Chiapua motor specs? | Nick Boyajian | Motors | 2 | 09-01-2002 06:14 |
| Motor specs | kmcclary | Off-Season Events | 4 | 26-10-2001 22:41 |
