Re: Where is the multi object tracking code for the RC?
They are not individual blobs they are a single large blob. The camera just draws a box around the target pixels.
If you load up easyC PRO we have a program in the Sample Code that shows what the camera is seeing. It draws a box around the blob and shows an "X" for the centriod (center of blob) and shows the data the camera is showing. If your not using easyC the CMU JavaApp also can show you the region. I don't know if labview can show this data. |
Of course if you used this method, the camera's servos would have to be driven by the RC because otherwise resetting the virtual window would cause the camera to track/center on that particular portion of the window. (I'm pretty sure anyways, haven't ever actually tested out the command). Can anyone verify that using the VW window causes the camera to re-process only that chunk of the view? Also I'm not sure if a sliding window would be too slow. Eagerly anticipating any more hints from Kevin! ![]() |
It's a fun problem <evil grin>. -Kevin |
i had a solution which i do not think is legal but would be cool.
Parts CMU Cam 2 x2 Basic Stamp Or Javilin BOE Programming Board Serial data into the free pins. Program the stamp to tack on a L or R to the packet befor sending it to the robot. That would allow for multi cameras but i dont think you can use a stamp. Maby a pic though. |
Thanks in advance, Robinson Last edited by gnirts : 15-01-2007 at 00:20. Reason: felt like it |
-Kevin |
While I would like it if we weren't angle sensitive, if we are, what math is necessary to figure out your approach angle to the target (eg. head on, coming in at 20*, etc.)? Thanks in advance, Robinson |
-Kevin Last edited by Kevin Watson : 21-01-2007 at 02:36. Reason: Fixed link. |
But also, I have an idea of how to determine the orientation of the rack/vision target from information from the camera and would like to know the feasibility of it. It draws on the fact that the blob size is proportional to the angle that your approaching the target from. the blob size will be "thinner" if you're approaching from an angle, and larger if you're approaching head on. Do you think it would be possible to determine the angle of the rack based on this information, and the distance? It seems that our robot will only be able to score(feasibly) head on. |
#10
-Kevin |
#11
Thanks, Robinson |
#12
I thought the general rule was that you couldn't come on the field with tape measure and other measuring tools to precisely position your robot. Other than that, you can place it however you want. That is the whole point. Last year, you could aim your robot "exactly" facing toward the corner or center goal so you could score. |
#15
The multi-object tracking cmucamera 2 code shown in the 2007 kickoff can be downloaded here:
http://first.wpi.edu/FRC/25814.htm This link was also accessible from the usfirst.org programming resource library accessible from usfirst.org. Anyways, I'm posting this because the intelitek webisite link ( http://www.intelitekdownloads.com/easyCPRO/ ) that was posted earlier, while containing the same code I beleive, is currently down due to exceeding their bandwidth. Michael 1353, Spartans Last edited by michniewski : 15-01-2007 at 22:44. |
| Changing the visibility of an object | 65_Xero_Huskie | 3D Animation and Competition | 9 | 28-01-2006 17:12 |
| Where to get the 2006 default code? | Eldarion | Programming | 12 | 15-01-2006 15:48 |
| where can I find the code for the first 15 seconds? | CompMaster | Programming | 2 | 16-02-2005 16:23 |
| Where is the CMUcam2 code? | Matthew_H | Programming | 1 | 14-01-2005 17:49 |
| The object of Zone Zeal???? | Jay5780 | General Forum | 15 | 09-04-2002 19:54 |
