#31
Re: "Smart" Breaker Panel Acceptable for '07?
I recall seeing teams from previous years using smaller (1 and 2 port versions) of the MAXI block. The terminal supply co PDF catalog isn't cooperating with me this morning, so I couldn't see if it still existed. But you are allowed to run another heavy MAXI block if you want. |
#32
I'll look for the 1 or 2 port MAXI... This could be really useful. Our large CIM is driving the whole *elevator* of our robot and needs to be able to lift quite a bit, so I think I'm going to stick with 40 amps. Thanks for the help, Jacob |
#33
<R45> Items specifically permitted on 2007 FRC ROBOTS include: One additional 4-slot Maxi-block circuit breaker panel and utilize it on their 2007 ROBOT in addition to, or in replacement of, the circuit breaker panels provided in the Kit Of Parts. Sorry, There is no other alternative. Ask this on the Q&A as I suspect they may be lenient in the use of single or dual versions of the Maxi block. |
| "If Robots Get too Smart..." | RoboMom | Chit-Chat | 9 | 07-06-2006 01:10 |
| New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" | Jessica Boucher | Team Organization | 0 | 10-08-2005 10:55 |
| "Thunderbirds" Vs. "Team America" Which one will rule the box office? | Elgin Clock | Chit-Chat | 3 | 07-09-2004 19:53 |
| Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? | gnormhurst | Programming | 3 | 22-02-2004 02:55 |
| 60Amp Circuit Breaker Mounting "Experience" | archiver | 2001 | 0 | 23-06-2002 23:57 |
