Go to Post Calling the refs "zebras" is just fine. Just don't call 'em late for dinner (or visually impaired). - EricH [more]
Unread 06-01-2007, 23:55
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Gear Spacing Help
I'm updating a transmission design without much experience and I can't find the right spacing to match the 50 tooth gear from the old KOP gearbox (5-11 in this manual) with the 28 tooth gear from AndyMark meant for the Large CIM motors.
I've heard "sum of the diameters divided by 2", but I can't find any dimensions for the gears. And which diameter? the teeth, or the bottom of the teeth?
Unread 07-01-2007, 00:15
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: Gear Spacing Help
You the "pitch diameter". Like you said, A rough rule is to use the sum of the two PD's and divide by 2. In some cases you need a few thousands of an inch more, but as long as you lube it properly, it willwork just fine with your formula.
Raul
I forgot to mention that you can find PD if you now the "Diametral Pitch" of your gears - DP's come in standard sizes such as 32, 20 or 16. This represents the number of teeth / inch of diameter. So, you can find the PD like this:
PD = Nt / DP (where Nt = number of teeth on a gear).
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 07-01-2007, 00:20
CraigHickman
Posts: n/a
If this is 20dp, or 24dp, I have the catologue of all Martin gears (a common supplier), and would be willing to look up all the sizes you need. Either shoot me a PM or AIM me.
Help Gear Ratios !!!!!!! Help sanddrag Technical Discussion 5 16-08-2002 15:09
Spacing of wheels? archiver 2001 4 23-06-2002 22:56
Goal pipe spacing too narrow to push balls through??? archiver 2001 6 23-06-2002 22:53
Gear/Sprocket Help Joseph F Motors 3 18-03-2002 07:48
Spacing of jugs and moveable goals luccul Off-Season Events 3 24-10-2001 21:01
