Re: possible ramp/lift configurations
Thanks for your help by the way![]() |
Anyone want to buy a motorized retractable ramp assembly, circa 2003? It was designed to have other robots drive on top, low mileage, etc. Heh, heh, heh. We call that robot "wedgie", our second year attempt.
Dick, We can't buy it, but we would love to see your drawings, photos & weight roll-up.
![]() Paul Pawelski first_team_2038@comcast.net Igneum Ferrum |
Our team considered doing this and just sitting there.
No, having a long tether is not allowed - This violates several rules, notably the 72x72 rule and the rule about not having a part on your robot which provides serious risk of entanglement (cable running along the floor.) In 2002, this might have been allowed, it wasn't until 2006 that there was a size limit. |
That year, we were using that 80/20 type frame material. We just slipped in some 1/4" Lexan in the grooves, put a plastic linear gear rack on the underside and fitted the window motors into the frame with the appropriate gear to match the rack. Due to weight and programming concerns (limit switches), we didn't use it in the competition. It was similar to those Jerr-Dan wrecker trailers with the ramp that extends down to the ground.
Another thing to think about is that if you are blocking your opponents tubes on the ground you are also blocking your human player.
Just a thought. |
Nah, you can't do that. Look at <G40> in Section 7 in the Manual.
| Motor Ramp Up/Ramp Down Function | Tom Bottiglieri | Programming | 12 | 03-12-2006 23:31 |
| To ramp, or not to ramp? | phrontist | Rules/Strategy | 27 | 26-01-2006 17:56 |
| Lift on cart | loomisman | General Forum | 9 | 21-11-2005 16:13 |
| Robot Pit Lift | Burg | Pneumatics | 19 | 14-03-2005 19:38 |
| Extension lift mechanics | Steve Compton | Technical Discussion | 8 | 25-01-2005 15:47 |
