MK 12 volt battery question
They said that we could ONLY use the MK 12 volt battery as our maing power battery, aren't they the same as last years batteries? the previous years batteries are 12 volt, can we still use them?
anyone know? -Thanks |
Re: MK 12 volt battery question
The batteries are slightly different from those last year. I'm not sure of exact specs. You are not aloud to use batteries from last year as this would create an unfair advantage to those teams who dont have those batteries from last year
-John *I do not know the exact model number off hand. |
Specs for the 2007 battery are here.
Specs for the 2006 battery are here. The new one appears to have about 10% less stated capacity at 1C discharge rate. So if you could use the older battery you might get an advantage over a team using the new one -- which is almost certainly the reason why the older ones are not allowed this year. For more, see this post. |
Sadly there's nothing we can do about that. Might as well learn to deal with it. Big disappointment but oh well. |
Not every team is going to be in a match at the same time. We do know how to share.
I speak from experience by the way. 57 takes just 3 batteries anywhere we travel and we don't have any problems. |
If that is FIRST's intention, I don't think it could be enforced. (How would FIRST know if a team brought more than two batteries to the regional?)
That said, I wonder if that is a mistake in the manual. |
#10
That rule was the same last year as well. You will be able to buy more of the same battery and use them, as long as they are the same as the ones in the KOP.
Expect a clarification in the Q&A or a Team Update. |
#11
No. I would interpret that to mean we can't use a battery in the kit, and another battery not in the kit at the same time on the robot.
#12
I would interpret this:
-Nate |
#13
Agreed. R46 covers what you can use ON the robot at any time. No using 2 batteries at once, no using a different battery on the robot. Doesn't cover what you can have at the comp. So I would expect some Q&As but no updates on that.
#14
Don't know if anyone has noticed this, but the new batteries seem a bit heavier as well. We pulled out the scale today and clocked them at about 13.5lbs, which is about 1.5 lbs more than the old batteries (someone correct me if I'm wrong that the old ones weighed 12lbs)
#15
There are some major differences between the two sections of spec sheets you posted. Quote:
| Battery question | CraigHickman | Electrical | 9 | 10-23-2006 09:55 PM |
| Extra Battery Question | 1337pcgamer | General Forum | 1 | 02-16-2006 07:58 PM |
| Question regarding to Battery Packaging | sxlterps | General Forum | 1 | 02-19-2005 05:37 PM |
| 7.2 Volt Battery | Justin_302 | Electrical | 4 | 01-28-2005 11:25 PM |
| Help!!! Battery question | trollin1st | General Forum | 7 | 02-12-2003 08:48 AM |
