Go to Post to all of the people who are on robotics, I thank you for giving me the chance and happiness that i had never had before. robotics has been the happiest thing i have ever done in my life - gondorf [more]
Unread 07-01-2007, 23:37
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Backup Battery life and the CMUCam
Does anyone have a definative reference for how the "backup power" circuit runs through the RC unit to the perhiperal devices (PWM, RELAY etc.)?
The "standard description" of how this works seems to be that the 7.2v battery is used to deal with sags in the main 12V supply, but that doesn't seem to be the case.
I've noticed that when I power the CMUCam off a PWM output (as recommended), after a moderate time of camera testing (with no other major loads) the camera stops communicating until I replace the backup battery with a fresh one.
I would have expected the RC to be powered by either the 12V or the 7.2V via diodes. So if the 12V is good, the 7.2V battery won't get drained... but that does not seem to be the case.
Unless this is just a matter of me using an incorrect output to power the camera, this is pretty annoying, since the rules don't seem to permit me to substitue the old-style AA NiCds with NiMH barteries that would give me better camera life.
I'm just trying to find a reliable way to ensure that the camera keeps running as long as the RC runs.
Is there a better "legal" way to power the camera? maybe run the camera off the 12V supply directly. Is it just as simple as me installing my own 5V regulator?
I know... a lot of questions.....
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 07-01-2007, 23:40
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Backup Battery life and the CMUCam
The backup battery is being drained because the servos are powered off of the backup battery. The standard acceptable voltages for servos are 4V to 9V (If I recall correctly), hence they are powered via the backup battery and not the main 12V battery.
Unread 07-01-2007, 23:56
PhilBot's Avatar
AKA: Phil Malone
OK, help me clarify what's going on then....
I'm not using servos on the CMUCam board, or the RC itself. In fact we didn't have any servos..
But are you saying that the +V pin on a PWM output is the unregulated 7.2backup supply?
I thought that these were +5v pins (but never actually mesured one).
So.. is there an output from the RC that does send out regulated +5V that can be used by the CMUCam? Is there a Schematic anywhere that shows the power circuit?
Phil Malone
Unread 08-01-2007, 00:04
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Please refer to this post by Kevin: here.
The digital ouputs do provide +5, however the camera has its own regulator and requires an input of +6.25 volts to function correctly. The only pins on the RC that output +6.25 volts or greater are the PWM outs.
Unread 08-01-2007, 00:11
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Yes. The signal to the Victors, as well as the power to any servos or external devices (like the CMUCam) comes from the backup battery.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-01-2007, 00:40
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Install an onboard backup battery charger.
<R56> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with the provided 7.2V backup battery charger. When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc. (note: IFI will provide the design for this circuit on the IFI website, however teams must obtain the parts for this circuit and assemble it themselves). The use of this circuit is strongly encouraged.
Unread 08-01-2007, 00:44
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Alan is right on. The link is a little hard to find off of the IFI website, but you can find the instructions for the circuit here:
http://www.ifirobotics.com/docs/firs...up-charger.pdf
_
Unread 08-01-2007, 07:42
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Actually the spec for the CMU cam is 5.2v to 8.6v. You can run the camera off the Digital Inputs, or Analog Inputs and it will run off the 12v battery instead of the backup battery. If you use any servos you should definitely build a changing circuit. Hope that helps.
Team 40 Runs a TTL cable directly from the RC to the TTL port on the camera. The camera gets powered by the RC and only requires one cable. If you go over 2ft of cable you should use a shielded cable.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 08-01-2007, 07:48
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You want to power the camera as intended so that it is up and running when the match starts including the servos. The camera derives it's power from the backup battery as that battery is the only source of power for the PWM outputs on the RC. An alternative is to use a larger capacity backup battery pack. You can specify a battery pack of your choice from Digikey and they will build whatever you need.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 14-01-2007, 01:58
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
Thanks Joey, I have been hunting for this schematic for a year...;-)
Jim Greenhaw
Mentor for 1388, Eagle Robotics
Unread 14-01-2007, 12:57
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
NO !!
The nicad battery pack has to be the same pack in the kit, or another of the same part number. Building a larger pack increases the amount of stored energy and is disallowed.
The correct was is to build the IFI charger circuit.
we built a circuit last year that was similiar that provided a 6 volt bus that was regulated down for the 12v bus. We ran the servos and cameras off the 6 volt bus.
Short answer, build the IFI circuit.
Unread 14-01-2007, 13:40
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
8.3.7 - Control System Rules
<R73>
... As a replacement for the FIRST supplied battery, any other
commercially available 7.2V NiCad battery pack may be used.
Unread 14-01-2007, 13:58
PhilBot's Avatar
AKA: Phil Malone
NO !!
I also questioned this interpretation, since the rules specify the voltage and material, but not the capacity. NiMH are out (bummer) but not a 7.2V C cell NiCD pack (as Mark pointed out)
We built a circuit last year that was similiar that provided a 6 volt bus that was regulated down for the 12v bus. We ran the servos and cameras off the 6 volt bus.
I also wondered about this... R63 would seem to indicate that a 6V regulator is an acceptable "Custom Circuit" as long as it it not connected to an output device. To me, this would make the CMUCam OK, but not a Servo. Hmmm..
My reasonning... Since a Servo contains a motor, and is covered by various motor limitations rules, and R63 says that a custom circuit cannot power a motor directly.... so........ wouldn't it be excluded?
Phil.
Phil Malone
Unread 14-01-2007, 14:01
Mr.D's Avatar
Mr.D Mr.D is offline
Randy Decker
FRC #0829 (Warren Robotics "The Digital Goats")
Team Role: Teacher
Mr.D is just really niceMr.D is just really niceMr.D is just really niceMr.D is just really nice
Do you know if a PC Board layout and/or parts list exists for this circuit? If not, I will be creating a PC Board layout and etching the board.
Randy Decker
Computer/Networking Technology, PLTW DE/IED,
and Electronic Systems Technician Teacher
Walker Career Center
Indianapolis, IN
www.warrenrobotics.org
2008 Boilermaker Regional J&J Gracious Professionalism Award
2008 Bloomington Vex Champion
2007 St. Louis Regional Champion
  #15   Spotlight this post!
Unread 14-01-2007, 20:15
Unsung FIRST Hero
Rookie Year: 1996
Phil.
Phil,
NiMH batteries are not allowed due to their unusual reaction when exposed to air. Regulators on custom circuits are allowed but they may not be used to power servos or other motors on the robot. They may (as interpretted in the past) supply power to sensors used in conjunction with the custom circuit. All control initiated by the custom circuit must be passed through the RC to control motors, lights, servos, pump, etc.
Al
WB9UVJ
www.wildstang.org
backup battery nirty Electrical 1 08-02-2006 14:40
Powering the cam without a backup battery Uberbots Programming 11 27-01-2006 10:00
charging backup battery Max Lobovsky Electrical 6 12-03-2004 10:24
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Backup battery and IR Matthew_H Electrical 6 21-01-2004 22:13
