Go to Post Congratulations! Welcome to the hardest fun you'll ever have. - Undertones [more]
Unread 18-01-2007, 16:20
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Risk of the Lift?
Originally Posted by 3@G13_1388 View Post
It is almost going to be impossible to use a lift to elevate your alliance's robots. It is going to be impossible because pneumanic cylinders are not going to give enough force to exert a lifting device.
im pretty sure that the pneumatic cylinders come in larger sizes than they gave us so i think it will be possible to lift other robots with a lift. and i thin the largest size is a 2 inch cylinder.
Cmon man you gotta put up a better argument than broad statements like "its almost going to be impossible..." or "im pretty sure..."...If you think teams cannot be lifted with pneumatics, you might wanna scroll through CD-media back to 2004 where quite a lot of teams used pneumatics to lift there 120lb+ selves............VERY SUCCESSFULLY
Get creative...impossible is a dangerous word my friend
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 18-01-2007, 17:28
pascoea pascoea is offline
AKA: Adam pascoe
FRC #0093 (New Apple Corps)
pascoea is an unknown quantity at this point
Why are you limiting yourselves to pneumatics? There are MANY more options that would work just fine.
And I would agree, things that were impossible 10 years ago are now old news.
Keep the good ideas coming.
Unread 18-01-2007, 21:51
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Why can't pneumatics lift? We used a 2-inch cylinder in 2004 to lift our robot and that was pulling. If you look at the math that 2-inch cylinder (the actual piston was probably smaller, lets say 1.5 inches) has 7 square inches of pushing power. At 60 psi that means that cylinder has 424 pounds of force. Now lets lower that estimate some for efficiency and put it at a mere 300 pounds just for fun. That means that with the number that our team currently owns (two) we could lift 5 robots off the floor to a height of about 3 ft. If we didn't lift us then with two we could lift every other robot on the field. They have more than enough power to lift your entire team.
However, I don't think that would be the way to do it cause that takes a long time to charge up for (and more than all of the storage that we got). I think a motor winch would be better suited. Also why is a lift more dangerous than a ramp? When rolling up a ramp the robot is moving on a very narrow surface and might drift without the driver being able to tell. When a lift is working then all of the force is vertical, that robot only moves up and not laterally (hopefully). No lateral force result in no lateral motion and so how does the robot topple? If the lift is done well I bet that it’s safer than a ramp cause it can be better automated.
Just a couple of thoughts
Unread 24-01-2007, 14:05
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
The 2" Bimba cylindar has a push factor of just over 3. So 60PSI in the cylindar will provide just over 180 pounds of pushing force . In other words, a single 2" cylindar has the pushing force to lift a robot.
Believe me, there will be a LOT of successful lifts.
As far as which is safer ... both are just as safe. The same amount of energy will be in either design because you are raising the robot the same height. Damage occurs only when that energy is expended (IE a robot hits the floor). The difference is who's in control of the robot at the time of an accident .
Unread 08-01-2007, 15:01
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
Team Role: Mechanical
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Now i dont know if this idea is good for use.. But what if you had a bar extend from the "lifter" robot on both sides, and other robots had their own lifting mechanism that would pull themselves up? it would be like 2004, execpt you must make it at least 12" of the carpet.
Unread 08-01-2007, 15:09
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
The only problem is if only one hangs, then they will both tip unless you have a way to stabilize yourself
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 08-01-2007, 15:12
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
This is very true.. that is why team 118 had 2 arms on our robot chainzilla during the 2005 competiton. We had noticed after getting a certain height off the ground that more weight on one side made the robot tip over more so we added a second arm to balance the weight and always made sure that both arms had a tetra on them.
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 08-01-2007, 17:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
If your robot cannot survive a 12" fall or a tip over onto it's back or side, you need to build it a bit better. That's my opinion. Robots will inevitably fall with or without platforms/ramps.
Unread 28-01-2007, 13:58
Mib Mib is offline
AKA: Aaron Clay
FRC #1741 (Red Alert Robotics)
Mib is on a distinguished road
Send a message via AIM to Mib Send a message via MSN to Mib Send a message via Yahoo to Mib
I think the best thing to do would be to test your ramp with last years robot, or with a human being on a cart (some kind of a test object)
Aaron M. Clay
Programming Consultent
www.GameCopyWorld.com
amclay (@) purdue.edu
Unread 28-01-2007, 17:27
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
Amen pull last years bot out of moth balls set it up just like you are planning on having the other robots doing it and give it a try. Worst case scenario you drop a robot you probably won't ever use.
Unread 08-01-2007, 15:15
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
I don't think we can determine which method is more dangerous since you can't know exactly how those two options are being accomplished. But if someone messes up their bot driving up a ramp it's their fault, which could be a different story with a lifter, so I'd opt for the ramp.
We've been thinking about a ramp that has a sort of jack underneath it to level out the ramp and raise your ally's bot. I see this as a combination of the two methods.
Unread 08-01-2007, 15:21
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
I think the practice fields will be full of teams praticing lifting to lower the risk. It would be nice if at the regionals there could be the practice field and then also an extra spot of carpet that the teams could practice lifting on.
Unread 08-01-2007, 15:23
Alekat's Avatar
AKA: Alex
That sounds good on one condition. A big sign that says "Weight Room" must be placed somewhere nearby.
Unread 11-01-2007, 16:53
AKA: Charlie Baxter
This is my personal apology for my "attitude" earlier. Turns out after crunching the numbers lift = lighter than ramp. So drum roll please 1741 is.......lifting!! We'll see how it works. I do have a question. If we were to use honeycomb (the metal used for certain surfaces on comercial air craft) and used glue to attach the skin is that within the rules? As they read it says that you may not use adhesive back tapes, but this isn't tape so I think its legal but I wanted other opinions if you wouldn't mind.
Thanks
  #15   Spotlight this post!
Unread 11-01-2007, 17:01
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
remember last years ramp was pretty steep and also made out of diamond plate neither of which are requirements for anyonesramp
Risk tournament [527]phil Games/Trivia 1 29-09-2005 17:22
Interface of the window lift motors Marjory Frosty Motors 3 14-01-2005 22:57
PHP as a security risk purplehaze357 Website Design/Showcase 9 02-07-2003 21:50
A little lift for the final week George1902 General Forum 1 11-02-2003 22:48
Amount of Force to lift the bridge? archiver 2001 2 23-06-2002 23:21
