Re: Risk of the Lift?
IMO, if done correctly, a lift can be just as safe as a ramp.
All I know is that at the competition I know there has to be an alliance where one robot will go onto another robot and then that robot will try to lift the other and then all three will flip over and the whole regional will go quiet while this happens. Oh and the pit area is going to freak out with the silence too probably.
My nightmare begins with a rookie team driving up our ramp full speed and crashing into our ringer arm. Ramps give me grey hair....oops, all my hair is grey as I type.
Ken |
I had an interesting thought. Lets say that my team has two independently lifting platforms set up so that the other two alliance members can drive on and be lifted when they are safely on and stop. Would it be worthwhile to have the other two alliance members hit the disbale button when they are on so they don't accidentally drive off and give us a reputation as a robot dropper.
alright i'm signing out of this argument 1741 has its methods don't you worry.
I wasn't refering to the ramp of last years competition. If you had a more shallow grade on your ramp it is easier to get onto. Also a ramp wouldn't require the counter balancing that would come with lifting a robot.
Right but by making the angle more gentle you eliminate the ground clearance issue as well.
#10
last year, people knew the ramp would be there, and they still weren't able to get up. this year, the ramp isn't actually a game element, so people will be even less likely to design enough torque, or a low enough cg. also, the ramp will probably be pretty narrow. i know that when running from across the field, with 10 seconds left, there is almost no way to make it to the ramp, get aligned, and get up in time.
#11
True enough. Most people wont be sitting in the home zone with like 30 secs left in the match to be sure someone knows there set up for the whole ramp thing. I think I lift would be much faster if pulled off right. As I posted in another thread A forklift can lift a lot more than its own weight with no worry of tipping, and even if there was a chance build safety arms or something on the side so at most the robot tips a bit and wont fall off. One foot isn't much so anything is possible really.. it will depend on the situation. but a lift is do-able.
#12
The ramp was angled more off the ground last year. This year we have the option of making the ramp relatively flat.
#13
So even a 'relatively flat' ramp may prove to be a difficult (if not impossible) obsticle. |
#14
In 2004 I saw robots drop from five feet and still manage to survive and function (after some repair work) one even went as far as the final four after it dropped from the bar. Unless you built your robot out of porcelin I don't think a one foot drop is all that big a deal. |
#15
On Galileo at Nationals during FIRST Frenzy, there was a robot suspended in the air, as high as the bar, 10 feet. The entire robot fell off the bar (yes, it fell all ten feet!), landed on polycarbonate and somehow managed to survive. Teams just have to take careful consideration when designing their robot. If you plan to drive up on any other robot, or lift other robots, you have to take the risk factor into consideration. Also, I think thats the risk that it takes when deisigning any robot. This is what makes the game more interesting to watch. ![]() |
| Risk tournament | [527]phil | Games/Trivia | 1 | 29-09-2005 17:22 |
| Interface of the window lift motors | Marjory Frosty | Motors | 3 | 14-01-2005 22:57 |
| PHP as a security risk | purplehaze357 | Website Design/Showcase | 9 | 02-07-2003 21:50 |
| A little lift for the final week | George1902 | General Forum | 1 | 11-02-2003 22:48 |
| Amount of Force to lift the bridge? | archiver | 2001 | 2 | 23-06-2002 23:21 |
