Go to Post Darn IFI and AndyMark for making quality products! :) - Gabe [more]
Unread 08-01-2007, 11:34
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
opening up the BaneBot gearbox to install the CIM motor
Note that the hex key required to remove the end plate on the BaneBot gearbox is a metric size 2.5mm.
An American size hex key will not fit, and may damage the allen head cap screw on the gearbox.
You can buy such a hex wrench at
McMaster Carr:
mcmaster.com
Search for part #: 7289A13
This is a ball-end wrench, which will speed things up a bit when loosening and tightening the screws.
Cost is $0.26.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Gearbox that can be used inline with a CIM bombadier337 Motors 3 11-03-2005 22:05
how to wire the new two motor gearbox Vince lau Electrical 10 14-02-2005 07:30
Can anyone confirm that the CIM and Drill motors are the same as last year? Jeremy Technical Discussion 2 12-01-2004 21:54
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
