Problem with program uploading
i cant upload program with easyCPRO i checked out the cable and tried on other computers but it still dont works can some one help me???
Re: Problem with program uploading
did you press the programe button?
Do you guys know were I can find the code for the camra. Or any info on how to use it, and see code that can give us an idea on how to include it in the code/recive info from it?
yes i did and the state of the led is always orange (meen i can upload) but it there still an error check out the program state or the cable but every thing is connected.
jesusfreakmths: Check out http://kevin.org/frc for some camera implementation code.
1573: In order to program your robot you will need to press and hold the PROG button on your RC, until two orange LEDs are illuminated. Once this is so, send the code with your laptop, but make sure that you have the correct serial port specified. If you are using a USB-To-Serial adapter, you may need to check which COM port it's mapped to. (Control Panel > System > Hardware > Device Manager > Ports (COM & LPT)). If you're not sure if your adapter is working or not, connect the serial to the program port, open the IFI loader terminal (make sure the window title says that you're connected properly) and hit the reset button on the RC. You should see an init. string. If not, the problem is in your adapter. |
no, the problem it all that i cant connect to the RC 2 leds are orange and in the program state but there still an error... and i chacked out the computer and tried on other but there the same problem
Try turning off "verify and download" in the loader setup.
Also make sure you have the correct device selected as easyC can program 04/05 & 06/07 & VEX Demo Camera Code: http://www.intelitekdownloads.com/easyCPRO/ Last edited by Kingofl337 : 01-08-2007 at 03:48 PM. |
nope still don't works the download setting is on frc 2006/2007 controler
easyC does not automatically detect (and can't possibly know) what port you want to use to download. You probably have the wrong COM port selected. Go to the 'loader setup' and try selecting another one of the available ports until you find the right one. If you are using a USB adapter, each time you unplug the cable and insert it again, there is a chance your COM port number will change.
If this doesn't help, try another loader. You can grab the hex file from your project folder and use another loader to upload it to the RC as a test. Good luck, Chris |
#10
nope, i dont understand what can be the problem i tried 2 controlers 2007 and 2006 controlers and tried in 2 computers with 2 diffrent loaders one from easyC and the other from MPlab but there still the same problem "To enable download, hold the 'PROG' button down until the 'PROGRAM STATE' LED is solid orange. Make sure that power is on and the serial cable is connected" any one can help me with that??
#11
What are you using for a serial port? USB or Onboard?
#12
Press and hold the Reset and Prog buttons, until the battery led solid green, and then release reset butoon. After that, release prog buttons.
uploading!! |
#13
click on FRC stuff ("here") scroll down, and it should be called something like frc_first_camera2 get the bells and whistles if you're doing a lot of stuff with autonomous mode, the streamlined version is ok though you'll have to upload it to the camera/robot, but after that, the camera should be able to track targets and display feedback |
#14
did restart it
#15
Did you try the IFI loader?
| Program Build Problem | douglass1371 | Programming | 3 | 02-18-2006 06:46 PM |
| HELP needed, problem with streamling, need uploading space or diffrent solution... | Nimmy | General Forum | 5 | 02-15-2006 11:18 AM |
| program download problem | zdeswarte | Programming | 5 | 03-23-2005 06:46 AM |
| Problem with communicating with STAMP through serial port | Skabana159 | Technical Discussion | 2 | 02-06-2003 09:10 PM |
